i hope a newer bios may make things easier.
i didn't pay £166 to overclock a dual core!
the asus p5k-e wifi for £85 could do it as well, plus giving a lot of extras
Someone over at my forums said that their board shows as a UT now, so might be better not to flash until I find out the details, although, I suppose you could always flash back if needed :D
which version of bios us the guy in anatech video ?
he had MCH values and me NOT !! i have bios of 20/3/2008...
i tried it all zanza always 1 error in memtest on every pass
i can do 1150 with d9gct lol
i gave up hope with d9gkx on this board mushkin and kingstons
the good thing i havent had dead d9s for 5 months now lol i was averaging 2 months per set on gigabyte @ 2.24v :rofl: :rofl:
MCH Vref 1/2/3 Value
where are this values ???? i dont have those on voltage control pannel!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I have a 9800GX2 and have ran Vista 64 bit without issues such as you've described. Have you tried a fresh install of vista 64 since the issue started happening? What about making sure both floppy drive connectors are connected to your mainboard for extra power? Are both of your power leads (2) connected to the top of the card as well? Have you also tried to swap slots the card sits in? Did you check to make sure the green LED on the back side of the card is lit confirming the 2 power connectors are right?
I did have an odd FPS issue that would come up out of nowhere, usually 1-2 days, and every game i played was -30fps from what it was previously and the screen would turn to utter chop. System restore back to original install and same :banana::banana::banana::banana:. I'd create a restore right after i verified my frames were silky smooth too. I went to XP 64 bit and haven't looked back and everything runs better =) I'm pulling 91FPS in COD4 @ 2560x1600 on my Samsung 30". S i L k Y!
I had that 30 fps issue on my MF. I had to reinstall directx to fix it.
With a clean install it does the same thing, It locks at boot up if the nvidia drivers are installed. When the drivers are not installed vista x64 boots fine. I'm only using one graphics card (so I'm not using the extra 5 pin connectors) and yes it's plugged in correctly. The system won't even post if the 8pin and 6pin connectors are not connected.
nah dude..
anandtech lately.. their clocking is really bad
look at that 500fsb 1200mhz CL5 clocks
i can do it with latencies less than 50..
they left everything at auto.. thats y...
hmm they even change their stand on cpu vdroop ..
last time they said to disable it for 45nm's
their trd setting too lax..
trd 7
7-5/(6/5)>2.75(6/5)
42/6 - 25/6>13.75/6
so its doable ..
just need more vcmh and vdimm..
Is there anyway to read SB temps? My Enzotech SB HS is cool to the touch but it would be nice to see an actual temp. Also, is there any software that will control the other fans attatched to the MB? We have control over the rear case, CPU, and NB fan but there are two others that i'd like to have control over as well.
Axis
First i see this
Then I see this:
You basically say Raja is a hopeless overclocker then you admit you can not do the clocks you say you can....which is it?
You know the test suit they run over at Anandtech is brutal, you guys living on the ragged edge would never be able to run all the benches and stability tests they do...plus remember they are not catering for on the edge people, they show what the board can do that is 100% stable ;)
I hope you were not running 2.4V into your flex modules as you just broke your warranty ;)
oops didnt mean to touch a offend anyone .. hmm maybe should have worded properly.. was kindda in fit with the physx card when i wrote that.. sorry to both of ya
but i was just refering to that dfi x48 review
just the ram part i find it unfair..
at least with the DFI p35 they went right to the sub timings.. settings etc.
anyways just enabled the vdroop since they change their stance on that.
cause this mobo rocks for rams as far as i concern.
yeah i know those guys run brutal test like for 3 days etc..non stop
anyways this is my stable 24/7 for 3dmark06 which i think is awesome
http://forum.lowyat.net/index.php?ac...post&id=457645
the 2nd problem for the cmos corruption was because of the 9800gx2 and a azuntech xi-fi card..
realised that now only after i tried a physx card...
redid it the whole day so anytime i use the second pcie for 9800gx2
and the last pci slot for physx or the azuentech ..
i get cmos corruption..
problem was solved by moving back the 9800gx2 to the first pcie
vantage scores - Performance Preset
http://service.futuremark.com/result...eResultType=19
new drivers 175.12 just increased my sm2 scores..
quote:-"the 2nd problem for the cmos corruption was because of the 9800gx2 and a azuntech xi-fi card"..
yeah everytime i clear cmos or if it resets it self i loose my azun prelude card driver and sound controller ! some may see , big deal just reinstall the driver and plug and play will find the controller , no way hozay !! windows doesnt plug and play , the driver doesnt install, its a massive headache.
so now i just uninstall it before overclocking then install it after wards. its the only way .amazing sound card though .
just curious did u have that issue with it?
Have you two disabled the onboard sound?
news about the new bios ??
yeh same i disabled onboard sound. u wouldnt believe this , after posting my comment on my sound card , i went into bf2 , plugged my mic in and this screeching noise went threw my speakers, my whole system crashed lol i had to reboot 5 times to get it going. now i have no sound at all. drivers are ok i reinstalled them there fine. hope i didnt kill my card. damn its brand new.:(
yeah i think i killed it theres no sound at all. :banana::banana::banana::banana:
I was playing around last night trying to get my board to do 8x500 and all i kept getting was a nasty beep and C1 post code. I couldn't get it to go away for the life of me.
What kind of beep?
Try with one stick of RAM.
Also, do a battery out CMOS clear, it can often fix problems like that :)
