zlojack: Always nice if you can post a screen shot when you do a test so I have some numbers to look at.
I'll start by assuming that you are not presently using an Idle calibration factor. My testing was at 1.08 volts (core) so at 1.20 volts, my numbers aren't directly comparable to yours.
Your choice of motherboard shouldn't really effect your core temperatures as the DTS sensors are within the CPU and will read the same no matter what motherboard you put it in as long as everything else like voltage and cooling are the same.
During testing I also have an open case to reduce other heat sources including a hot graphics card or two.
Are you using the same cooler on both? If so then I would suggest an Idle setting of about -1 or -2. When the new version of RealTemp comes out then you could be a good candidate for Idle=-1.5 ;)
I managed to sneak a couple of more features in while the boss wasn't looking.
http://img504.imageshack.us/img504/8...eaturesim9.png
In the tray you can choose whether you want to look at the Minimum, the Maximum, the current Core Temperature or even the Average temperature since starting the program or hitting the Reset button. Does the competition have any features like that? I don't think so!
