Does this usually require a +0.1 to PCIE?
Just got my x38-ds4 and e8400 in, downloading 45 vista updates :ROTF: ... i tried to run core temp but it says it need s a digitaly assigned driver, so maybe these updates will fix it?
it looks like bios is reporting the temp right for me, it has 24-26*c depending on what i set the fan speed to :shrug:
i'll post some results up in a bit
EDIT: i need help, all the temp monitoring programs still say they need a signed driver, what do i need to get?!
I think you need to turn off the need to have a signed drivers in Vista, I'm not sure there are signed drivers for the free download programs? I don't envy you trying to get your computer or the programs to work with Vista. I fought with Vista tooth and nail for several months, it was an extremely frustrating experience. I have gone back to XP Pro and haven't thought about my O/S since.
What VTT and CPU PLL are you guys using on any current overclocks your Orthos testing on?
435 x 9
Vcore: 1.2625 ~ 1.24v Hardware Monitor
CPU PLL: 1.50v ~ 1.632v HM
FSBT/VTT: 1.36 ~ 1.30v HM
Optional: CPU GTL: Auto
vtt : 1.2v
cpu pll : 1.5v
cpu GTL x61
nb GTL x61
450x9 4050
VCore: 1.28 ~1.28 HM (I have done a vdroop mod)
CPU VTT: 1.13 ~1.15 HM
MCH (FSB): 1.54 ~1.58 HM
GTLREF CPU 0&2: 68%
GTLREF CPU 1&3: 67%
My stupid overclock
Evga 780i + E8400 Intel Pentium D Stock Heatsink.
8.5 mult x 500 FSB = 4250 Mhz. Mult using CPU/N2.
Core 0: 52 Celsius Core 1: 49 Celsius
1.408 V
Vid: 1.112
No way I am gonna stick with this clock 24/7, but I wanted to see what my chip could do.
1)I tried 1.33V for 4050 but it was no go
2)So i kept my 1.3V and lower to 3950. Prime still no go.
3)I did not went over 1.45V. And this voltage for 4.5GHz was only for one hour benching session.
4) I have the Maximus formula. I kept these settings in 24/7 and in benching
PLL was minimum to 1.5 but mobo overvolts to 1.6
FSB Termination to 1.2 but mobo undervolts to 1.1 because of Wolfdale. With
my E6750 previously 1.2 was 1.2 no undervolting. That means that Formula
has considered the right FSBTermination for Wofdales.
5)Since first day i was running at 1.3@4050 and after the benching session i had
the degrade.
Conclusion for me:all wolfdales that needs low voltage at start will degrade and reach those that are not good overclockers (e.g. 1.45V@4GHz) even at low voltages.Even if i have not raised the vcore to 1.45 i would still have the degrade in my opinion.
To sum up in order to bench at 4500@1.45V
CPU PLL: 1.50 ~ 1.6 monitor
FSBv/ VTT: 1.20 ~ 1.12 monitor
CPU GTL: 0.63x
NB GTL: 0.67x
Here is mine, FPO Q746A513.
It can do 8*480MHz (3.85GHz) @ 1.272V, tough on the screen its 1.288V but now at this moment I am running prime again with 1.272V...
Its a shame, I wasnt able to stabilize 8*500MHz, even with 1.368V under load, which is 1.384V idle, from BIOS 1.4250 coz' if vdrop...
I didnt want to push it more...
I also raised NB voltage to 1.55V, no help, SB to 1.60V no help...
WinXP loads up fine, AND IF CAN GET to desktop I can run Prmie95 or ORTHOS for gours, no error, no freeze, temp max 65 celsius, SEEMS fine...
BUT after a reboot, 3 out of 5 times when login screen comes up, i type my password, hit enter, and it stops there! Doesnt lock up, just slows down... it takes about 3 mins to get to desktop, but I can only see background, no start menu no icons...
Mouse still works, num-lock led active, so its not frozen but still, something wrong....
Could be this my mobo...? Cant handle 4GHz OR its my CPU...
As u can see it handles 8*480 absolutely stabel, 12+ prime95 small fft's test ran fine...
Any idea?:shakes:
http://aycu26.webshots.com/image/419...6138517_rs.jpg
On my Abit IP35 Pro to get RAM stable using 8x CPU multi at 1:1 512 FSB I had to up MCH voltage to 1.37, might even have to up it one step more, need to check. Wasn't any probs with 9x CPU multi using ram multiplier x1.2 with a lower FSB to get the RAM running at up to DDR2-1150 speeds without having to up the MCH voltage though.
Most of IP35Prot for 500 1:1@2x1GB fsb needed 1.41volt.
For 510 1.48volts for 526fsb 1.56 and so on.
With 5:6 divider 1.41 is needed for 450 fsb.
My giga board does the same. I think it's a way for the CPU to say "stop stop!"
I have a question. What is more important to performance? FSB and Rated FSB or The actual clock?
I'm wondering because I think I can go a lot further on my chip if I put my chip back at 9 mult and 1.45 vcore.
I have to say that even at 3Ghz this chip is much much better than the Pentium D 3.2 Ghz that it replaced.
On another note I found out something weird on my motherboard that lets me know if a clock works or not. When my comp starts, if it hitches and then continues during the mem test, then I know the overclock won't work.
Actual clock.
My latest on E8500 Q740A493T on Asus Commando 1605 bios
3dmark2001 run @5003Mhz :D
512MB Inno3D 8800GT OC Edition stock hsf @742/1836/2000
http://fileshosts.com/intel/Asus/Com...2000_87756.png
AM3 @5092Mhz
http://fileshosts.com/intel/Asus/Com..._283143_tn.png
Will recieve my retail E8500 on thursday or friday. Hope it will work with my ix38 quad gt...
Where are you guys getting the e8500's can you post a link to an international shipper??
i think im in love, im running orthos at 1.28v @ 4.0ghz (only about 30mins in so far though) :D
My bios seems to be reporting the correct temps, they fluctuate perfectly. So it looks like im getting 43*c load and bout 25*c idle. I'll post some screen shots up in a bit
