nice.. :)
:woot:
nice.. :)
:woot:
The latest Alpha BIOS and AMD System manager will allow those FSB rates now. However, if you drop a 8800 or X1950 in the board, and then run dual 32M Super PI or Orthos, your FSB rates will come down in a hurry. ;)Quote:
Originally Posted by mascaras
maybe not if you have a chipset block ...:D...2x gpu blocks and a cpu block too.
my kingdom for a good kentsfield and a pair of R600 :rolleyes:
btw bingo13 i would love for you to possibly post some details as to how exactly you guys managed to tweak the mobo for max performance....
especially if you're running micron D9GMH
/a little OT pic for fun
can everyone say ghetto! :P
http://i60.photobucket.com/albums/h1...zor/blocks.jpg
strapped on for fun
I have a 2G kit of firestixs saved to be used in one of these
Originally Posted by flytek
really nice.. :) hehehe :woot:
Very smart way 4 hold down [the tie wrap way] if some1 dont have thin screws , :toast:Quote:
I learn something today :fact:
Well I had that board, but then it didnt go over 390 FSB :( ( I didn`t know the trick with PCI-E frequency to ~120 :( ) .Quote:
Originally Posted by Tony
What about the last bioses? With Conroe.. goes over ~440 FSB w/o any mod? 10x :)
Sorry for the OFF.
ok..maybe I am dense but why would this occur?????????Quote:
Originally Posted by bingo13
Originally Posted by Supershanks
That's some good work you've done with the pics. I've got both the Ultra120 and the Hr-01 waiting in a closet as I'm using an AC cooler which is more than enough for my stock E6600 right now (shi-tty board). I'd rather use the Ultra to the rear fan as in pic 1. But the cooler might not get the clearance needed in the top of the P180. We'll see, but it looks possible after seeing your post. I might need to loose the top fan in the case though...
I'm gonna do an exotic air cooling setup for my rig after a get my hands on this board...
Originally Posted by M3kk
sorry to go OT... to get 440fsb at 10x you are going to need some exotic CPU cooling and probably a volt mod on the northbridge and perhaps a VFSB mod.
UK release ETA 12/01/07
Going by the chipset temps he is pushing 2V into the NB, all well and good for brownie points but under advice from AMD I was asked to quote safe limits for voltage etc which is around 1.5V max.Quote:
We can do the same speeds here no problem...safer bet though is a high multi CPU just like it is on the 975 boards
As this board finds its way into more hands before release, I suspect we'll see a few more "I got 5XX FSB!!! on my RD600". 2007 is gonna start pretty well for the enthusiast community with the RD600 & Abit IN9-Max 32. Tony have you got yours yet? When you get a chance to toy with it, most of us would really like to know which of the two boards you "enjoyed" overclocking the most.
I have IN9, just got it booted up and started tests. You need to have a fan on the CPU header for it to boot and im water cooling so at first I thought the board was dead :(
Anyway...i will start a new thread with some early results, this one belongs to the RD600 ;)
T
wow :D
ahhh.. hope this boards will be on retail soon.. ive been conroe less for a month now.. :(
waaaa..
bingo13 could you post pics of your setup.. :)
Yep it passed the time :). I'd prefer to use my ultra to the rear as well & have modded my lian -li to handle the overhang from a big cooler. Conroe Ready:) Modded Lian -Li V2000b+Quote:
Poodle -
Just dissapointed that it appears that after market coolers won't fit the r600 nb.
luck:)
So basically with a lower multi cpu, you're still better off with a P965 board?
performance-wise NO!
Given the poor RAID performance being reported by a couple of sources on i680 boards vs. intel (see this thread), I'm curious how the HDTach results look for a RAID 0 array on this board?
Can anyone provide some?
read back bud, i posted some
http://www.xtremesystems.org/forums/...&postcount=474
You do not want a Kentsfield on this board if you plan on overclocking at this time. I am finding that a 345FSB or a little less is the absolute best for running a stable system. The board will POST up to 401x9 but is not worth anything more than a good screenshot. DFI has started to tune for Kentsfield now but I still expect the 975/965 boards to be the best bet for it.Quote:
Right after CES I should have our part two article up along with the BIOS settings for maximum performance.
On a side note - I did 545 on the RD600 with an old FX5200 card (too much heat and power draw with an 8800GTX to get past 530), voltages to their limits, Alpha BIOS, and it failed SP 1M three out of four times but by God I could get a screenshot of the one time it passed. :D I just love the run and gun results. :rolleyes:
hahaha...:D
looking foreward to the expanded article :)
shamino did some messing with gtl-ref voltage and claimed to get an extra 30fsb from a kentsfield...but you've probably tried that allready.
his write up is on his site vr-zone.com
after the tweaks he said he could almost reach the fsb he achieved with a p5b-dlx iirc.
Sorry... thanks Tony. Would be nice to see a test with 4 drives in RAID 0 to compare with the peak output of the other chipsets that have all been tested with 4x 150GB Raptors (where i680 is looking bad), but I understand you probably test with what you have on hand.Quote:
Hopefully when people get these in their hands, we will see more RAID benching.
you guys heard about the latest delay >> March
what are the REAL issues plaguing these Tony? Surely you would have encountered some serious issues that are not allowing them to release these motherboards
Originally Posted by dinos22
Are you not thinking of the R600 ?
