sorry I didn't reply! Thanks for the info. I have looked into them but 200 is a lot of money. :(
I will have to start doing some more research on it again. I started working on it something like a year ago! I got a very nice yagi antenna.
no problemo - you can always check flea-bay or craigslist - just don't respond to any job offers. Heard something on radio about a girl who got lured to her death via a babysitting job on craigslist. Way too many sick B@$t@rds out there.
I have looked on ebay before but they cost more then the ones you posted a link to! :D
I didn't even think about looking on craigslist. :shrug:
Well like I said I will have to do some more reading and see if I can find something again.
I'm probably going to get this silverstone case . It's over 8" high and the cpu will be on the side of the case that has the most vertical clearance - at least if I've got everything figured out correctly. The TRUE 120 is 6.3 inches tall so even with 8.3 inches, it will still be tight - m/b + plate + standoffs is probably close to an inch. In the worst case I'll have to RMA a couple things.
It only has 2 fans, but it looks like I can add one more 80mm fan - can't be sure till I get it. Plus the psu will have a 120mm fan so that should give it enough air.
I went with this one - there is just shy of 7" from mb tray to top. Had the same micro atx or not debate
http://www.mountainmods.com/h2go-ano...c4qi0odhr89va1
I passed 500k the other day. :)
Yaowzer!!!! You got more scratch than I do. That's out of my price range. I shouldn't be building this system at all, but I been jones'in real bad and I can't stop myself.
I'm still working on it but at this point I think I'm going with a cheap Athenatech case. I'll post everything once I think I've got everything together. The specs say it's 7" high so the true 120 might just fit - especially if I give it a good lapping :D
gratz guys.. :DQuote:
WesM63 passes 75,000
OriginalCyberDruid passes 25,000
JungleMaster passes 50,000
Pisu87 passes 50,000
Conquistador SW passes 25,000
123sarah passes 10,000
I broke the 13mil today AND moved into the top 100 (rank 98th to be exact) AND easynews is still down :D :up: :yepp:
Great job team! :up: Let's go let's go .. :rofl:
Congrats to VietOZ, Wes and all the others who are helping us to move higher.:up:
:yepp: Tonight I'm going to break the 1 Mil milestone (WCG points)
Congrats! :toast:
grats...Quote:
jspace passes 500,000
bartsimsonii passes 5,000
Mekoa passes 1,000
rcofell passes 250,000
xtyphoonx passes 10,000
coldmm803 passes 100
coldmm803 passes 50
Hicks121 passes 50,000
RTP passes 50,000
MotF Wiggy passes 2,000
Passed 100k Boinc points today! :woot:
Let's add another zero to that.
Excellent!!! You have 41million points for majestic 12. I could look it up, but if you feel like telling me what that was about I'd be interested. Those are some serious numbers.
Looks like I am a little over 2mil pts :) they do add up :)
He mumbles to himself.. need more quads...
Cool, I'll have to try it out - just on principle. Google is over $700 per share - or it was yesterday - that's just obscene.
Congrats to ShootStright for passing 5 million in BOINC, and to WindForce for passing 3 million. That translates to more than 35 million and 21 million WCG points respectively.:toast:
