I will try that, but about the RAID?
I will try clipping the 9th wire. I don't have USB on my case. I have one of those 21 to 1 card reader/usb things that occupy a drive bay. I also have the USB thing that comes with the motherboard (and installs in a card slot hole). Would I clip the wires on those? I also have a SEAWELL 7 port powered USB hub, would I clip number nine on that too?
On another note. I have my system set up to boot two drives on a RAID 0 (that is my drive c). Then I have 2 drives on the IDE 0 channel (which are my old saved data) and 2 CD drives on the IDE 1 channel. With this setup RAID does not work after BIOS 7.16
I am thinking of getting a couple SATA drives and replacing my IDE HDD's and just remove the problem all together. Then I will have a RAID 0 boot, 2 backup single SATA drives. Then I need to figure out something for the 2 DVD/DL drives.
If I'm not mistaken either HDD controller can be set up to be IDE, or RAID right? So what you are suggesting is switching which controller I am using for my RAID?
Rattletrap
