Seba u know ... nice :up:
New build (again)
Sorry for the amount of photos, i got a bit carried away :p
http://i30.photobucket.com/albums/c3...s/PICT5292.jpg
http://i30.photobucket.com/albums/c3...s/PICT5300.jpg
http://i30.photobucket.com/albums/c3...s/PICT5294.jpg
http://i30.photobucket.com/albums/c3...s/PICT5295.jpg
http://i30.photobucket.com/albums/c3...s/PICT5302.jpg
http://i30.photobucket.com/albums/c3...s/PICT5304.jpg
Updated my loop
http://i292.photobucket.com/albums/m...PC/WCPC010.jpg
http://i292.photobucket.com/albums/m...PC/WCPC013.jpg
http://i292.photobucket.com/albums/m...PC/WCPC003.jpg
http://i292.photobucket.com/albums/m...PC/WCPC005.jpg
http://i292.photobucket.com/albums/m...PC/WCPC019.jpg
http://i292.photobucket.com/albums/m...PC/WCPC016.jpg
http://i292.photobucket.com/albums/m...PC/WCPC021.jpg
added Feser 1/2" ID tubing, Enzotech NB WB, EK-RES 250, HW Labs Black Ice GTX M184, Lian Li Thermometer
nice, it looks really clean, what coolant/ dye are you using?
damn! your rigs are so COOL! :up: i should be saving up for a water-cooling system :(
Thanks:up:
Two bottles of Feser View - Active UV Dye - UV Blue mixed into a gallon of distilled water using Feser Tube Active UV Hose - 1/2" ID (3/4"OD) Anti-Kink Tubing
Here are some pics of my first water cooling set up. It went very well with all the advice I was able to get from the forums!
http://i254.photobucket.com/albums/h...Picture023.jpg
http://i254.photobucket.com/albums/h...Picture025.jpg
http://i254.photobucket.com/albums/h...Picture015.jpg
http://i254.photobucket.com/albums/h...cture001-1.jpg
http://i254.photobucket.com/albums/h...Picture002.jpg
http://i254.photobucket.com/albums/h...cture021-1.jpg
Mr 326
Nice work ... very clean... and a nice short loop, you must of got some good advice, alot of people use way too much tubing..
can you let me know what temps your getting ??
Darren1981
Thanks for the compliment. Before I had water, I was using a Tuniq tower 120. On air the max oc I could get was 3.4ghz. At that speed I got about 62c at full load. After I went to water, it gets up to 49c at full load. Also, now I got it to be stable at 3.6 without too much effort. At 3.6 it gets up to 54c under full load.
Sorry for the delay...just one of those weeks. Also based on WL feedback:
...I confirmed with AC that the res does contain aluminum. I drained the loop the day after WL's post. While I wait on a new res, here are some pics before i drained the loop and removed the res:
http://img261.imageshack.us/img261/56/dscn2987fb9.jpg
http://img177.imageshack.us/img177/2762/dscn2973lr6.jpg
http://img360.imageshack.us/img360/2...talled1wh8.jpg
I like the shelf you have your case on. :D
Hey sheriff_deadeye, i like how you moded the PSU from back to the front. think if i got that case, i can fit an HX1000 up there?
Sheriff, Where’s the PSU exhaust fan located? Is it blowing the hot air towards the hard drives?
A little update on my build, still not complete
http://i44.photobucket.com/albums/f4...y/DSC00459.jpg
http://i44.photobucket.com/albums/f4...y/DSC00460.jpg
http://i44.photobucket.com/albums/f4...y/DSC00462.jpg
Can I say yummy!
Nice build there :)
http://i114.photobucket.com/albums/n...Picture708.jpg
http://i114.photobucket.com/albums/n...Picture713.jpg
Mostly the same ole shistuff but with a new case.
What's the block on ur 8800GTX?
Looks like a stock cooler te me :S
Its a CoolerMaster Hydra.
http://www.hardwarecanucks.com/forum...er-review.html
Its actually a good cooler, the barbs are restrictive.
Nice builds
The 550 is : 5.9"(W) x 3.4"(H) X 5.5"(L); 150mm(W) x 86mm(H) x 140mm(L)
the HX1000 is: 150mm(W) x 86mm(H) x 200mm(L)
I also moved the hard drive cage and rotated it 180 degrees. Once you remove one of the two cages in the v1000 and decide to move the other one, you can fit the longer power supplies - front or back. I used the standard lian li psu mounting plate to mount the psu.
The PSU intake fan is on the bottom and the exhaust is towards the front of the case, away from the drives. When i moved it to the front, i also rotated the PSU 180 degrees since normally the exhaust would be towards the back of the case.
Even though the PSU is not blowing on the drives, there is a lot of heat build up around the drives. I have an 80mm fan where the psu used to be in the back, but there's not enough air flow to cool down the drives. I'm trying to improve the air flow around the 80mm. If that doesn't work, i'll have to cut a fan hole in the side panel.
hey guys heres my water cooled rocket fish
http://img382.imageshack.us/img382/5248/imgp0291od7.jpg
