Oh I didnt know that. I guess I better do my homework then :slap:Quote:
? A new microarch is prepared for late 2007/2008 , called Nehalem , designed by Intel Oregon , 45nm and the cake on top : it has an IMC.Quote:
Originally Posted by alpha0ne
:woot:
Where did you get that info from?
Calling something a new micro-architecture isn't the right term, the Core Microarchitecture most likely will last a few years but it will be evolved in the same way the P6 microarchitecture covered the Pentium Pro through to Tualatin Pentium 3's, or Netburst covered the range of Pentium 4 designs.
Hehehehehehe, come and get me....these are default settings and both the cpu and card have MUCHMUCH more ;)Quote:
Originally Posted by M.Beier
http://service.futuremark.com/compare?3dm05=1953943
http://img89.imageshack.us/img89/1243/923dr9ll.jpg
Oh, BTW, I forgot to tell you: I'll have a t2600 yonah and aopen board within 2 days for testing :hehe:
Sorry for the OT :p:
Maybe people should do a little more reading and a little less posting.Quote:
Originally Posted by Formann
If you dont know what decent to good benchmark numbers are then you simply haven`t read enough.
Placing X2 benchmarks in a Conroe thread makes it harder for people to find out how an X2 performs...
When I look for AMD info, I look in the AMD or O/C forums, and when I look for Intel info, I look in the Intel or O/C section.
Go figure :stick:
Sad to see common sense illudes people that think they are so damn smart.
Time to unsubscribe, this thread has become a bad joke made so by a very few :rolleyes:
Hmmmm........:p:Quote:
Originally Posted by Rocket
BTW, this thread won't be updated by Victor until the ~21st of this month anyways as he's away on business.....
I had a dream last night...:stick:Quote:
Originally Posted by NiCKE^
The stuff is like this :
Intel Israel designed Banias( 1999 ) ,then Dothan ( 2001) and started Yonah.
Intel Santa Clara took over Yonah and Intel Israel was given a new job : Merom ( all this happened in early 2002 )
Intel Oregon ( which designed the P4 ) had its Nehalem project based on Netburst killed in late 2003 , together with Tejas.In early 2004 they started a new Nehalem , a brand new microarch which is set to arrive in late 2007/early 2008 and replace Merom 2 ( 45nm )
In late 2005 Intel Israel started to work on another new microarch called Gilo which will arrive around late 2009-2010 timeframe and supplant Nehalem.
Basically Intel will have 2 design bureaus fighting each other and bring new stuff every 2 years.I hope AMD can sustain the pace , altough they look very confused right now ( killed K9 , K10 , stopgap K8L, new microarch in 2007 which I hope it is not K8L :nono: ) not knowing which to target : Merom 2 on 45nm or Nehalem ?
If this new architechture has an internal memory controller then it won't need 4mb L2. L2 cache makes up for high external memory latencies, and I think Conroe still hurts when it hits system ram, the fsb bottle necks it.Quote:
Originally Posted by RimRam
But 4mb shared should be more than enough to overcome this problem in the short term, and the transistors are cheap for Intel.
More cache always helps , especially in commercial aplication and for servers where you need scaling.Quote:
Originally Posted by Iconyu
How much it helps when you increase its size depends on how well you implemented it.
For example , it is possible that AMD's poor results with DDR2 are a combination of the modified IMC* ( 2x8 wide data buses vs 1x16 on 939 ) and its L2 line size.
*It isn't yet clear they took the 2x8 way like Intel 9xx, but it looks like it.
I came to this conclusion, after witnessing AMD's tactics with their switch to socket 939. Their 512k's did indeed perform close to the 1mb's on the 754 socket. The performance gap was very almost identical to 512k vs 1mb on the 754 at the same clocks.
I'm not saying I'm right, after all I joined this forum to learn more, and it would be foolish of me not to take each post with a open mind. There's a great depth of knowledge around here that I'd like dip into.
this thread is 99% spammed...:nono: :nono:
why the :banana::banana::banana::banana: are you talking about amd in intel section if noone didn't ask for it..
open new thread "flame one amd vs intel" and post there
Look at the voltage on that beast, 3volts.
Yeah , and it pulls 119Amps.Can you believe how hot it must be ?Quote:
Originally Posted by P8baller07
1.2 volts, not 3 volts.
And your purpose for even posting this bs was what again? You are grouped into the small few that have ruined this thread.Quote:
Originally Posted by Rovtar
Seriously mods, erase the bs posts in here or just close it.
Ok guys this thread has gone waaay off topic.. So now its closed..
