no it isnt temp , you have not enough voltage on gpu to it 600mhz , it s all :pQuote:
random lockups during overclocking means that the gpu is not getting enough volts or that it is just clocked too far, or both.
For some reason newer ATI cards will not artifact on the gpu, they just hard lock and u have to restart.
My card restarts my comp at 627 gpu and i get artifacts for memory at 637. So for the gpu i have to raise the voltage?!?!? to get it higher....hmmm ok is there anyway to do this without vmodding? like through windows/dos or somthing? and whats the stock voltage this card runs at..Quote:
Originally Posted by MaxxxRacer
nope, sorry, only multimeter+soldering/pencilQuote:
Originally Posted by $JG Money$
u have an x800gto2?
Yes yes i do :D
not only new wannes , think its the drivers .Quote:
my x800pro , and gto² have bothe hard lock up :p: whene the oc' is not stabel
i just bought a gto2 from overclockers.co.uk
the card is a vivo dual dvi card with r480 core 16 pipe enabled stock
out of the box max gpu 515 higherst ram i have tested 600.
flashed with the modded techpowerup bios and still the same.
i have a vgpu mod but the lowest it will set the vgpu is 1.49 it will go past 530 gpu but is stil unstable. gpu temp showed 62C but the whole card as realy warm ram was almost hot to the touch.
i think with better cooling it will go higher.
still very happy with the performance at 500 / 600 for the price.
by new, I mean X800 and later. So that will include all the X cards.
oh i see, im coming from a 9800p so this is a whole new world of graphics, either way, ive got my old 'SP-94 on it, 400g of heatpiped copper works in my favor either way i figure... out to do well with a 92mm panaflo, i cant do the vmods until next weekend though hehe.
Hello :)
My Sapphire gto2 was 16 pipes out the box :D
It does 640mem 590core on stock cooler/volts but locks up in 3d tests. 580/640 is stable :D
Would flashing to x850xtpe raise voltages maybe give me higher core ?
Would i make things worse with it already having 16pipes open ?
Whats the best bios to use ? :scope:
Thx for any advice :toast:
I just got GTO2 and I flashed it to X850XT PE.
Then I overclocked to about 580-590/640 is my maximum.
So I think it's because of cooling, so I changed it to water cooling.
The temperature drops a little bit, so I try to overclock it again.
And it's can go only 590/650, if it goes just a little higher, the screen is going to be frozen and it just shuts down.
What about you guys??? Do you have the same problem???
Or this is the maximum that this card can go???
yes. same here.
imo no solution. try mod?
Yeah I think it's able to go higher but I don't know how????Quote:
Originally Posted by webwilli
Dang, i guess the new dual DVI cards didn't came any good to oc when compared with the the non-VIVO.... Lockup at > 560MHz :(
3DMark05 - 7334
Wow nice score.. how come i only get 7030 on my 053dmark? 2.8ghz(opty144)
and 600/600 on vid card with 16p enabled. And only 29233 in 2001se? WTF!!! such a big difference in 2001se score? what am i doing wrong...id love to be that high and i kno it can be done:(
29233 @ 2k1 se isnt enough with rthis clock.Quote:
I do more than 30K with Gto² at stock under winxp sp2
http://img460.imageshack.us/img460/8...tock9zm.th.png
My results with a gto2 ... low clock for the GPU :(
Here mine, Maximum at 580/640
My card started balcking out in CS: source.
ran at stock, same, anyone else have the problem?
Originally Posted by Pekkie
as said on the page before this one, newer ati cards dont artifact, they just lock up, its not temps, its volts, you need more.
Hi
Have Sapphire X850 GTO² 12p @ 16 p
actually running 540 Core and 600 Mem (So 1200) (ATI Tool 0.24)
Both GPU and VGA ram modules are on water.
Issue is :
When running intensive games, i get some strange little artefacts :
Demo NFS Most Wanted
Far Cry 1.3
BF2
Halo 1.2
x-plane 8 also....can't run it 1280x1024 full details with this set...A64+X800 GTO² modded :(
I think those are due to heat or a lack of voltage....but the entire water circuit won't go higher than 44° overall temp....minimum fan level ;)
I've read that other members have this issue.
Bad serie R480 chips?/Bad ram modules??/??
Keep it coming :rolleyes:
Impressive Cooling.
What are your temps?
I konw the cooler...Thermalright??;)
Is your rig silent??:D
Will post some updated 3dmark 03/05 scores caus' Dual core is on the way :)
P.S. : Would you use Catalyst 5.12 or 5.13......:confused:
Maybe Omega drivers.....?
yup thermalright SP-94... IMO much better then an XP-90... but less compatible ;)...
my rig can be dead silent but i turn fans up just a bit for gamin to keep cpu cool, have a TT BT on the way to fix that though.
anyways in ati tool with 580mhz it gets to maybe 38c under artifact scanning. This is about 20c cooler then with a vf-700 for me.
edit -most up the time my OCZ PS520w is louder then the rest of my rig... someday ill end up with a seasonic i guess.
edit 2 - personnaly i always use the latest cats...im not that hardcore though.
hey guys!
i ned the stock mem timings of a x800xt, x800gto (2) or x850xt.....
i din´t found anything....
