Can winchester go sub-zero?
Its still Hit or Miss. :( Some do some dont. Give it a try and let us know how you do. Good luck.
my new 3000+ 0448SPAW:D
watercooled, hope for 28sec. suerpi1m:D
My dead winnie 3200+ killed by a DFI mobo :mad:
http://valid.x86-secret.com/show_oc.php?id=3606
+1Quote:
Originally Posted by bass
3000+ cbbhd 0448 Spmw is Dead (dfi nf4 -> Boot vcore 1.85v :( )
Box Amd -> Tower outside :toast:
1.55v Bios
http://www.membres.lycos.fr/boblemag...max3106mhz.PNG
3200+ cbbhd 0447 Tpew
dfi nf4 ultra d
box Amd -> Tower Outside :toast:
1.7v bios
http://www.membres.lycos.fr/boblemag...ie@3140mhz.PNG
Only Max Screen :cool:
What's the temperature outside Bob?
my 24/7 settings:)
0° approximately (it snow :D )Quote:
Originally Posted by zeebs
how did the dfi kill it? :confused:Quote:
Anyone that couldn't run a Winnie @ full power r404a prommy (-50ºC +-) but it could run with the prommy fans off? (-35ºC +-)? Mine runs with the fans off, but my prommy has a leak now and cant test the OC, so if anyone can run them with the fans off share your results :P
You french are lucky with your steppings. DK has at least medicore steppings, the US seems to have hollow crap at the moment :(
3000+ CBBHD 0447 TPCW on STOCK AMD FSH, running @ 9x300MHz=2.7GHz with 1.55v vcore & RAM (with 9/10 divider) running 270MHz @ 2-2-2-5 3.5v vdimm.
+24 hours Prime95 stable, now runing F@H for about 13 hours error free. :)
here is a screenie:
http://www.xtremesystems.org/forums/...chmentid=26033
/// EDIT ///
hardware used:
AMD 3000+ Winie & STOCK AMD HSF
DFI NF4 LP Ultra-D with 2.17 BIOS
2xOCZ 512MB VX
ATI Rage Mach64 PCI! :banana: (my X850XT should be here next week)
Enermax NT 480W
http://home.scarlet.be/~pascpiet/DV/...50WPBW_WHS.jpg
http://home.scarlet.be/~pascpiet/DV/...P2004_5h29.gif
http://home.scarlet.be/~pascpiet/DV/...9_OCCTT_OK.gif
Not WaterChilled, juste WC with water hole -> Water = 12°C
http://forum.bel-hardware.citywebz.c...topic.php?t=62
:toast:
The three-phase power delivery circuit next to the cpu socket sparked, and thats what killed my poor cpu :mad:Quote:
Originally Posted by saaya
But I'll have a 0448 SPAW to play with tomorrow :D
I will be sending the board back to DFI on tuesday for rma, so I'll be playing with my msi neo 2.
I have a 3200+ CBBHD 0450 SPBW too.Quote:
Originally Posted by Feinripp
It runs over 15 Hours Superprimestable at 2600 @ 1,45.
On a MSI K8N NEO4 Platinum with Stock 1.1 Bios.
Temp is just at 37 Degree Celcius.
This is my 3200+ CBBID 0451 Stock cooled, DFI Ultra-D and 512Mb BH5.
CPU always arround 2630Mhzs 1.65v, mems @ 265Mhzs 2-2-2-5 +- and 330HTT =)
http://pwp.netcabo.pt/orlandojdr/winnie12k.jpg
http://pwp.netcabo.pt/orlandojdr/winnie32s.jpg
http://pwp.netcabo.pt/orlandojdr/mems7.5k.jpg
Complet opn?
CBBID 0451 xxxx ?
ECK
APAW i think or SPAW.Quote:
Originally Posted by EclectiK
i have this proc in my signature and i'm very unhappy with it...just can't find any stable combination
tried several things in bios...nothing is 100% prime stable...what shall i do ????
so far stable 240-255 * 9 max.....and needs a lot of juice... :(
After a Day of tweaking
http://users.pandora.be/CyrusTheViru...%20Mem@240.jpg
AMD Athlon64 3200+ @2883 Boxed Air 1.66V
ASUS A8N-SLI Deluxe HTTx 4x286 (Vcore & Vdimm Mod)
Corsair Twinx PC3200 BH5 @240MHZ 1.5*-2-2-0*-1T @3.3V
:banana:
With room temp op 10° Case 16° Max CPU 25°.
The case stands near a open window
ROFL at that guy who removed the IHS.... Way to butcher your processor... If you would have just slid a razor blade lengthwise under each corner and lifted, instead of stabbing at the sides, you could have had it off in 15 seconds, without all those scars... I hope after all that it at least helped your OC...
Obrigado :)Quote:
Originally Posted by diogojcr
But is it possible to have the exact opn please?
Thx for that
ECK
My setup :
MSI Neo2 Pl
2*512 Patriot XBLK
AMD 3000+ 0445 SPAW
http://Www.easypanic.be/3075.JPG
stable @ 29xx MHz for Pi :)
http://Www.easypanic.be/pi29sec.JPG
Full CPU code:
3200+ CBBHD0450TPFW
http://img209.exs.cx/img209/3158/5m21s2lw.jpg
Winnie 3200+ Cbbhd 0447 Tpew
DFI NF4 Ultra D
2*256 Adata BH5 (0313we) 2/7/12/2/2/2/5/2/2/1/2 -> 3.9v
Box AMD -> Tower Outside :D
Xp Lsd 2 :(
No patch :)
http://www.membres.lycos.fr/boblemag...uperpi28s2.PNG
