It mean's that alot of use don't like Silenx very much... and thats putting it mildly
bad
my mess
http://shrani.si/thumbs/img010411rdg.jpg
http://shrani.si/thumbs/img010511rdh.jpg
suggestions? :D
why don't you face the infinity in line with the exhaust fan instead of the psu ? you can move the rams to the black slots instead of yellow for space. cable management needs work. what fan is on the infinity ? if its the scythe stock fan it will be sleeve and be weak to push air upwards horizontally.
yeah stock fan...
"why don't you face the infinity in line with the exhaust fan instead of the psu ?" well it's the way retention module is....
My Stacker:
http://img294.imageshack.us/img294/4683/panoramamk6.jpg
http://img294.imageshack.us/img294/9305/img0154py2.jpg
http://img171.imageshack.us/img171/1821/img0200sa0.jpg
Abit AN8-SLI
A64 Venice 3200 @ 2.6 (260x10 @ 1.5v)
Evga 7900GS
2x 1024Mb Patriot DDR500
ThermalRight XP-90 - AS5 (May lap CPU\HS sometime)
Zalman VF700-CU - AS5 (HS doesnt need lapping)
Stock Abit OTES Chipset cooling - AS5 (May lap the contact plate, add AS5 Epoxy to the plate\heatpipe connection)
Mods:
-Placed Plexiglass in bottom and side vents to prevent noise and dust buildup.
-Added aluminum rail onto ETX hole mounts, Used for cable management.
-Added holes in Motherboard for cables
-Painted Interior with textured black paint, texture is like 800 Grit sandpaper.
All fans are 5v / 7v
Its VERY quiet. I'm ~1 Meter away from it right now, And I can only hear my HD clicking every so often.
prospect: does that foam helps to lower noise and vibrations etc...
@ kevinbo03: realy nice uv-effects. :)
@ _Prospect_: is your case not a little bit too small?? :D
Here's mine -
These pics are with my previous mobo (P5N32-E SLI).. now i have switched to a DFI P965-S Dark, so i'll update some pics when i get time to take them =P
but here they are~
http://i98.photobucket.com/albums/l2...frontangle.png
http://i98.photobucket.com/albums/l2...inside_gfx.png
http://i98.photobucket.com/albums/l2...side_whole.png
http://i98.photobucket.com/albums/l2..._frontside.png
http://i98.photobucket.com/albums/l2...kbox_front.png
custom made 90degree angled power connectors~ oh yeh! =D
http://i98.photobucket.com/albums/l2..._optical_2.png
nice man, really clean comp you have there
wow, spooks does your pc actually look like that or is it some photoshoping?
lol nah its not photoshop. the photos just ended up like that maybe cause of my unsteady hand and the effect of the uv's =)
and also my :banana::banana::banana::banana: camera.. LOL =)
Very nice! Powdercoating or spray paint?
thanks mate! haha its just normal spray paint~ sanded my case back after i finished modding it, primed then painted away~ =D
@ spookz: realy nice uv-effects. :clap:
spookz
Very nice
Simplicity ;)
Hi Im new to this forums!
My Air Cooled Stacker 830
http://i25.photobucket.com/albums/c5...4/IMG_1082.jpg
http://i25.photobucket.com/albums/c5...4/IMG_1083.jpg
http://i25.photobucket.com/albums/c5...4/IMG_1086.jpg
http://i25.photobucket.com/albums/c5...4/IMG_1087.jpg
http://i25.photobucket.com/albums/c5...4/IMG_1088.jpg
http://i25.photobucket.com/albums/c5...4/IMG_1089.jpg
Intel Core 2 duo e6400@ 3.0GHZ, Soon to be e6850
Zalman 9500AT, Soon to be Zalman 9700 NT to match the green theme
MSI P6N Platinum 650i motherboard
2 GBS Buffalo FireStix Memory @ 4-4-4-12 1t
2) EVGA 7900GT KO with Zalman vf 900's
Western Digital 500GB HD
OCZ 700 GameXStream Power Supply
CoolerMaster Stacker 830
BenQ 19in 2ms LCD monitor
please resize ur images specially since they are not very good looking due to bad camera
EDIT:
Thanks for the resizing and now we can figure out the look of ur system much better
i adore the 830
but an update from 6400 to 6850 is not the best bang for buck, i guess getting a Q6600 will be better or keep ur 6400 longer
Yes, that's true. Also helps for the ones that don't use a broadband connection.
But the system looks good, IMHO. Nice setup you got there.
I'm generally not much into looks of a system, but rather focused on its function and overclocking potential, but this does look nice IMHO, like many other systems posted here.
Welcome to the xtreme. :D
Nice rig spookz :clap:
I went into a deep thought, I built systems for the purpose of gaming. I play games online and need performance. I heard too many terrible cons of quad core on old and like new games. If games later on this year, take advantage of it, then I will certainly upgrade to it.
Maybe I will go with the e6750 for the 4mb cache. But the q6600 at $266 USD will be a great value.
My current rig that most I did on 1.4 vcore was 3.2 stable, without touching northbridge, link or any other voltage.
Oh BTW, sorry for the large pics, Its a Old Canon 4mp, my canon 8.1 is in used:(
Thanks for the comments.
http://i71.photobucket.com/albums/i1...-/SA400492.jpg
Nothing special, i'm not a handy photographer either sorry :P
