http://img49.imageshack.us/img49/695...32large7um.jpg
http://img69.imageshack.us/img69/195...38large3ph.jpg
http://img69.imageshack.us/img69/722...39large1ru.jpg
Cheers, i do like to keep tidy, makes it nicer with the side window, i agree with the aerocool but it was my mates desire so fair playQuote:
Originally Posted by mindwreck
@bullit, very nice, i love the clean look of the small diam piping, and the two rads in a pc60 (or pc-7)? is brill, like the fassmatic.
Big bore 7/16 or 1/2 for me though, love the flo
It´s not a Fassmatic but the original one the aquatube from aquacomputer.And thanks.Quote:
Originally Posted by bennywidag123
I just Love the combination Lian Li with Aqua Computer, looks awesome, to bad their performance isn't as good as the looks !
Another CM stacker. With an asetek kit (i know, but its my first :rolleyes: )
http://i24.photobucket.com/albums/c3...ark_proper.jpg
http://i24.photobucket.com/albums/c3...agon/front.jpg
ppkstat: I take it you like PPK?
Lol! Sorry to dissapoint you Maxxx but actually I picked my nickname because it was nonesense (i.e. it meant absolutey nothing).
Ppk are ok though:toast:
lol.. as long as you dont like ruki vverh...
Maxx you do know ruki vverh ?
Russian ?
cooper, no im not russian, but my friends are and so is my GF, so I hear alot of russian music.
:toast: MaxxxRacer :toast:
Well, got the new Storm rev.2 & BIP I in. Opted for a T-line this time instead of a bay res. Was interesting filling the system...
I am by means no photographer.
http://i1.tinypic.com/opciug.jpg
http://i1.tinypic.com/opcj85.jpg
http://i1.tinypic.com/opcjl0.jpg
http://i1.tinypic.com/opcjvb.jpg
http://i1.tinypic.com/opck1t.jpg
http://i1.tinypic.com/opclft.jpg
http://i1.tinypic.com/opcox2.jpg
My setup its swiftech apex kit with the storm block and the MCW55 vga block i also put that 90mm fan out of my case which was at the top there to cool that down cos it used to be real hot to touch now its not also is my loop in the right order
don't know how good the pics are cos i took em with my phone
maratus, lol.. I see your russian as well.
Nicksterr. Looking good there. D5 for the pump im guessing? And is that 120.2 radiator a MCR220QP?
Yep, you guessed it. Well a MCP655 to be more exact, but the same thing really. It's on the bottom of the case in front (In drive by area)Quote:
Originally Posted by MaxxxRacer
Nicksterr
Nice, but those hose clamps... I think worm is much more secure, right?
:DQuote:
I have metal worm clamps on the inlet and outlet of the pump.
First go at water :D
http://img392.imageshack.us/img392/8...00827jo.th.jpghttp://img202.imageshack.us/img202/6...stem5xk.th.jpghttp://img202.imageshack.us/img202/1...eim29zz.th.jpghttp://img215.imageshack.us/img215/8...oud10xa.th.jpg
Parts List:
LOGISYS CS600SL Mid ATX
Eheim 1250
Storm
Shroud made from storm door that fell off my porch
Zalman Fanmate
Some hardware store 3/4" Vinyl tubing
Some (overpriced) 7/16" Tygon
Fedco 2-199 Heatercore
95% distilled water, 5% cheap-o antifreeze
Based around an NF4 Ultra D
Opteron 165
ccbwe 0534spmw
OCZ Value VX 2x512
Coolermaster RS450 PSU
Here is a graph of temps for 30 minute idle-load-idle cycles comparing the four heatpipe AMD HSF, a Zalman CNPS-7000cu and water:
http://img433.imageshack.us/img433/6...0mhz0sl.th.jpg
Here is how the processor scales with voltage:
http://img357.imageshack.us/img357/3...freq3go.th.jpg
nicksterr .... exactly how hard is it to get the zip ties off whenever you change components?
not hard at all, takes a matter of seconds. I just clip them with my pliers.
Dtek whitewater
Dtek Res
aquaxtreme 50z
Danger Den heater core
sanyo denki push/pull
USPS box
http://img.photobucket.com/albums/v7...jogo/setup.jpg
http://home.earthlink.net/~unccvsa/s...es/inside1.jpg
http://home.earthlink.net/~unccvsa/s...res/inside.jpg
http://home.earthlink.net/~unccvsa/s...sidebehind.jpg
http://home.earthlink.net/~unccvsa/s...s/mounting.jpg
http://home.earthlink.net/~unccvsa/s...es/mounted.jpg
How can i do thumbnails?
thanks
i've added some more uv lights in better spots in my case. i'll update the pics in a couple days.
My first "real" watercooling system of my own... (Installed TT Big Water in my parents pc for practice.. :) )
My system..
Asus A8N-SLI DeLuxe
AMD A64 3700@2950
2* POV 7800gt@525/1200
OCZ 2048MB Dual Channel Platinum
SilenX 600w 14 dBA iXtrema PRO
Watercooling Parts:
Alphacool NexXxoS XP
Alphacool NexXxoS NBX-N
2* Alphacool NexXxoS NVXP-3
Alphacool AP910 Centrifugal-pump 12Volt 900 l/t, 22dBA
Black Ice Xtreme 3
Watercool AB-K Maxi res.
Kuriyama 3/8" tubing
http://img92.imageshack.us/img92/2855/innialt8fi.th.jpg http://img411.imageshack.us/img411/5...amme9ft.th.jpg http://img411.imageshack.us/img411/120/kjling7xj.th.jpg http://img297.imageshack.us/img297/7...nsin5cx.th.jpg
This is my water cooled computer, I redid my original kit - a Kingwin Arctic Liquid Cooler with a car heatercore and longer tubing so I can put the radiator out my window in winter, sort of a winter water chilling. I can lower my cpu temperatures 21'F (12'C) before condensation starts forming on my water blocks. The specs for my system are listed in my signature. I can run my Athlon XP 2500+ to the speed of a 2800+ on the stock vcore but never really tried serious overclocking. My 6600 GT can overclock from stock 500/900 to 590/1093 almost 100mhz core and 300mhz on memory :banana: And excuse the crappy pictures, my digital camera sucks and doesn't have a focus.
3dmark05 http://service.futuremark.com/compare?3dm05=1659174
The whole system - btw, those are blue led christmas lights :cool: :
http://img325.imageshack.us/img325/2737/dsci01682dr.jpg
From side:
http://img417.imageshack.us/img417/6091/dsci01699yf.jpg
The tower - The top unit is a Pioneer TX-960 digital radio tuner and the bottom is a Acoustic AI frequency equalizer and spectrum display, both units are connected through my audio card, my subwoofer is under the desk. The stuff on top is a 10gb portable laptop hard drive i made for less than $20 including hard drive from garage sale, a starting capacitor from an air conditioner, some cds and some blank cd's as well as some electronic christmas trees that blink when you hook them to a 9v battery:
http://img484.imageshack.us/img484/5032/dsci01770zo.jpg
My EL keyboard with modded num/caps/scroll lock leds - they were originally green:
http://img404.imageshack.us/img404/5592/dsci01746uw.jpg
An inside shot, it's hard to see but the PSU lights up (threw some blue leds in):
http://img346.imageshack.us/img346/6542/dsci01759uw.jpg
My external radiator with 120mm fan - and my cat :D :
http://img481.imageshack.us/img481/9141/dsci01811dn.jpg
@ Sveinbra
I like. I want to mount my dual120mm rad in the top of my stacker like you have your triple but I'm not sure how I'd go about doing it.
