2600K Batch L050A853 on Water.
http://img822.imageshack.us/img822/4896/38636021811.jpg
Nice chip Kensek, 1.55 at 53 is not bad.
It runs 5.3GHz with less, but last night I tried to see if running more voltage would get me more speed.
It didn't just created more heat.
http://img42.imageshack.us/img42/7272/38449.jpg
Vantage and Win7 SP1 should be drawing more vcore...
You guys mind shooting me your default VID plus max multi, aka not your max stable speed.
I want to know max multi you can get passed the blinking cursor on asus and or the max multi you can post bios without 4E post code on giga if not using turbo.
I just starting playing. L045A912 2600k from Newegg
4.6Ghz
http://3dxtreme.net/other/Sandy%20Br...47.33%20AM.jpg
4.80Ghz
http://3dxtreme.net/other/Sandy%20Br...-primedone.jpg
5.0Ghz
http://3dxtreme.net/other/Sandy%20Br...07.22%20AM.jpg
This is my bench chip, seems very similar to rogers.
Maybe I need a tad more vcore than him because of the added stress with ram at 2133 versus 1600.
Thats about as much prime as i'm willing to toss at it.........L042B144
Benches 5.5 all day long.
So my L050A864..
Can do 55x100 but 5512 is the maximum frequency I can reach.
http://www.outofspecs.gr/forum/attac...6&d=1298205398
http://www.outofspecs.gr/forum/attac...7&d=1298205406
:up:
Has anyone here lapped their SB?
GeorgeVasil, are you on water? what are your temps like at 5.5?
My 2500k was lapped. I did it.
http://www.xtremesystems.org/forums/...d.php?t=266765
Nice job dnottis - I read your thread.
Stick with MX-3.
I have the same batch with a SN of 2021 as the last four digits and my P67 Pro can only take it to 48x103=4.944Ghz at 1.50v vcore. Mine was bought from Micro Center locally here. My L042B208 was sold about two weeks ago and I just sold my L040B305 as I can't wait for more P67 boards anymore. Was thinking of holding on to them for more testing on different boards but the heck with that...by the time P67 boards are in full swing again, a better batch might surface and I might not have any more $$$ to spend.
Yes,
1x240/1x360/D5/Eleven block/Full Rpm@Fans
~43-48C@Bios
2500K Batch# 3044B310 on Air 55x100.3
Here is my o/c results
Why my batch# is different...without L0 IN THE BEGGINING
51x100 @VCore 1.464 load
2600K Batch#L044A892 SN# 2L040025A2527
Arrived today. Still testing...
http://www.abload.de/thumb/a-batch-51x100qm4z.jpg
Timoleros - So much volts on air? Is it snowing there or something? What are your load temps like?
@aussie-revhead:With less Vcore it wasn't 32M benchable...
My max load temp to the hotest core when I run 32M is 71c
@Dumo:I will try with ss at the end of this week...I hope to reach >55x
I7 2600k L041B213 Watercooling
5.430 3Dmark 1.610vcore /wprime 1024 1.585vcore........... ok
but can not read HD x55 x56....? It read in bios
asrock P67 Xtreame 6
opdat
Hmm mem bug ore bios
here is x55
opdat :)
What is this and how do you fix it?Quote:
