I got a M4N82 Deluxe to the side I got from a buddy last summer for building him a new am3 system.
He gave it to me because his computer fell over, from a table to the floor and his drive bay wasn't attached to anything, it ripped 2 of the sata ports out of the board, leaving the pins.
He still had the plastic cover for it.
I did some reasearch the next day, seemed like a decent board.
I called him up, asked if I could come over and get that cover, thinking I'll carefully slide it back on, he told me he tossed it :\.
Not sure if I should pull the pins or rma the board.
Board is working though, I know it posts fine and the other sata ports work.
I'm looking at asus'es site right now, newest bios: 2010/12/16 ^^.
Actually it looks like this board is updated alot....
Surprised me when I noticed it supports the 6 core cpu's (might come in handy if my mem comes back and my setup is still not stable...).
I think if you can get your point across, they will fix the probs you have with the bios.
It appears to me that they are still supporting some of these older boards.
And when I say old boards, I mean am2.
Try looking for good ddr2 mem on newegg, 99% of it is gone.
I sure as heck wouldn't want to go looking for some decent ddr2 right now...
That's why I say, these am2's are old.
It's hard to get good mem for them now.
Right now ddr3 is in it's prime, lots of good stuff.
The 1 gig sticks are getting to hard to find, but 2gig sticks are half the price that they were last summer.
And they aren't your 1333mhz 8 timing bs either, you can can get some decent stuff for reasonable price.
I don't see bingo around this thread much anymore though.
I kinda wish that the engineers would appear in the thread as well to help out.
Now if they can continuesly update a nvidia board, which is is a very very old chipset regardless of what it's labled.
Then there is no reason why a 790fx shouldn't be supported...
But after a year and a half, these board's, the supports goes downhill.
That's the way it is with all brands.
You might get a small update that supports a new cpu, but the usability of that update well, ^^...
One more year and the ch4's will be in the same boat.
Might even be quicker if the am3+ boards come out and the cpu's.
Then we can all say bye bye to good bios updates for these...
I doubt they will support the am3+ cpu's if there ends up being a 192 or 256bit mem controller.
I knew that though, I just wanted a good board to go with a decent 6 core cpu.
Bah, now I'm rambling...
