with cooler weather upon us. it maybe time to get my old 920 back into the top ten.. :D
Hi guys!
Here's my run. Cooled with Xigmatek Balder, the window was open and it's about 2'C outside :). Board was P35-DS3L, vCore in bios 1.375, idle 1.344 and under load 1.296.
http://i1089.photobucket.com/albums/i358/Nr2/4500.jpg
Load voltage:
http://i1089.photobucket.com/albums/...2/loadvolt.jpg
Nr2,nice E8400:up:
my old one did 4.5GHz w/1.29v too
and yours is the only other E8400
ive seen do that :D
you should be able to hit 5.0GHz with 1.50v to 1.56v
great submissions everyone,this thread is the best
and has the best SS's.and is also very well kept-thanks zalbard:up:
Thanks radaja. I would need a tad better board than the DS3L for 5GHz im afraid :D.
Just wait until you see this one :D
Looks like I was right...night time temps are dropping and I had some time to test this chip out properly. In a couple more months with 20C lower ambients, I'm sure these will improve even more if I get around to testing it again, as long as I don't kill it :rofl:Quote:
Originally Posted by miahallen
Gigabyte GA-P55A-UD7
Intel Core i5 670 - L935B898
Corsair Dominator GTX3 @ 1.64V & QPI/VTT @ 1.3V
Corsair AX1200
FFF&FMcooling with ~12C ambient temp
Some pics of the setup (Fluke showing air temperature outside the window):
http://i161.photobucket.com/albums/t...h_P1020242.jpg http://i161.photobucket.com/albums/t...h_P1020241.jpg http://i161.photobucket.com/albums/t...h_P1020240.jpg
Most impressive to me was this run with a full 4GB installed and running at DDR3-2000 CL7....4GHz QPI, and 2C 4T :up: (unfortunately, the best result IMO also won't be listed in the OP, go figure :p:)
1.5125V set in BIOS LLC-LV2
http://i161.photobucket.com/albums/t...len/LinX02.png
So I still needed a couple OCs for the OP....
2C 4T
The next step was to remove 1 DIMM and try again...
1.5375V set in BIOS LLC-LV2
http://i161.photobucket.com/albums/t...len/LinX04.png
2C 2T
And lastly I put back in the full set of memory and ran with HT disabled
1.55V set in BIOS LLC-LV2
http://i161.photobucket.com/albums/t...len/LinX03.png
The CPU didn't seem to want to scale with more voltage (or it didn't like the x26 multi, which was the best multi under LN2 a few months ago :shrug:).....if I have time in January or February I'll revisit with really cold (-10C or so) ambient temps :cool:
miahallen,WOW!!very impressive OC's
that is an awesome cpu,5.0GHz HT on w/1.50v:up:
miahallen that is very sick indeed:eek:
congrats love the modular cooling setup btw:up:
Thanks guys, yeah...this CPU is kick a$$ :)
Bloody awesome stuff, guys! Updated! :up:
About time Zalbard :shakes:
JK :p:
The 2nd two screenshots should both be in the OP though....the 2nd for 2C 4T and the 3rd for 2C 2T :cool:
Hi, guys, I m going to get another W3520 3845A935 that should be a very very nice CPU, so, I ll try to ram it up a bit, we ll see :) cheers
hehe nice clocks here :). I can try some day my new i7 980x under air. Just i take a jacket, open window at night and will see :)
4C 4T
CPU batch -W3520 # 3919A657
mobo - RIIIE
cooling - water
vcore @ 1.52V
http://img337.imageshack.us/img337/1...s21x215.th.jpg http://img804.imageshack.us/img804/5...s21x215.th.jpg
ASUS Rampage II Extreme BIOS 1802
Intel Core i7 950 202х23 4600 МГц 1.42v Watercool HEATKILLER® CPU Rev3.0 1366 CPU Water Block
Samsung M378B5273CH0-CH9 4096x3, 1333 9-9-9 1.5 @ 1600 8-8-8-20 1.6v Water MIPS RAM Freezer 6
Arctic Silver Ceramique
GeForce GTX 480 800 core / 950 mem
WD3202ABYS 320x6 (RAID Edition3) STRIPE 1.74Tb (1740 Гб)
Enermax Revolution 85+ 1250W
24 Samsung 245B 1920 x 1200
http://radikal.ru/F/s54.radikal.ru/i...b028e.jpg.html
CPU E8400 + water cooling
MB EP45UD3R
RAM Crucial Ballistix 2GBx2
PSU Corsair HX 620W
Vcore 1.4325V
MCH Core 1.40V
ที่เหลือ Auto
Dram 2.22 V
http://images.temppic.com/17-10-2010...0.38444900.jpg
Thats a realy nice E8400 nice results ;) nice fsb to, gigabyte boards are king in p45 OCing.. with the DFI and the ROG series ofcourse :)
What does this error??
http://www.shrani.si/t/x/cE/1GYDlN4F/ttttt.jpg
Now I put the cpu VTT +300. What is the cause of the BSOD STOP 0x0000007F
Zalbard...the OP still incorrectly lists my 2nd entry as 2C 2T ;)
