No sorry, I don't think its possible without removing the cable from the board:down:
I don't really understand why you would want to do that, if you are sleeving that cable I assume you would be sleeving the whole PSU, which requires removal of the PSU & all connectors.:shrug:
If your board only takes a 4 pin plug you can remove the other plug by cutting the wires where they are joined at the pins. If you need the 8 pin it would look better if you shortened the wires that go from one plug to the other. You would need to get some new pins though.
You can use an extender but it would not be good for cable management as you have more wires & connectors to try & hide.
Remember we are only sleeving for aesthetics :D
