Think the P5Q Pro 1406m might be released today? :D
I didn't think it would work.
im excited
Hey Ket, think you could do something a bit better for the MFII??? The board is really lacking in the "bandwidth' dept... I'm using your mod bios 1307 currently, didnt know if there was "bigger/badder/faster" availible??
:cool:
Probably could rejig a M2F BIOS, but I'm flat out with the Biostar mod right now.
It would be most appreciated whenever you get a chance man......:cool:
Anyone tested these new bioses yet?
Just give them a go :p:. On a happy note all of my stuff turned up today, XTC mem cooler, 80mm and 40mm fans, brand spanking new P5Q Pro, got lots of toys to play with! :D
yea i tossed em on my pqe-e and sofar they are just as good as the 140x w/e before these. AND i can see the plashscreen again <3
hi, im a n00b ocer here! wat is the url link for the latest p5q pro mobo? my stock bios is the 1104v .... im currently doing a stable 3.68ghz with hi vcore BIOS of 1.4000v using the E5200 cpu , so KETs modded bios allows 'finer/better' tunings/settings then the stock bios?
also how do i flash the bios , i DO NOT have a floppy drive :(
heres most of my bios settings:
*using ASUS p5q pro w/ E5200 stable 24/7 @ 3.68 Ghz as of oct 15th 6:30am est. *
FSB frequency ===================> 320 *now
multiplier =========================> 11.5
pci frequency =======================> 100
FSB strap to northbridge ===================> auto
DR ram freq =====================> 802mhz
DR ram timing control ====================> auto
DR ram static read contr====================> auto
DR ram read training ====================> auto
MEM overclocking charger===================> auto
AI clock twister ====================> lighter
AI transaction booster ==================> auto
cpu voltage ====================> 1.4000v
*cpu gtl return ====================> auto
*cpu pll voltage ====================> auto
FSB termination ===================> 1.50
DR ram voltage ===================> 2.10* kinda hi???
NB voltage ====================> 1.42 kinda hi???
*SB voltage ====================> auto
pcie sata voltage ====================> auto
load line calibration ====================> disabled
cpu spread sprectrum ====================> disabled
pci spread strectrum ====================> disabled
*cpu clock skew ====================> auto
*NB clock skew ====================> auto
cpu margin enhancement ====================> optimize
in Advance CPU settings:
CPU ratio =====================> 11x multiplier
C1E support==============================> disable
*max CPUID value limit ====================>*enable y or no
*CPU TM function ========================>*enabled
*Execute Disable Bit ======================>*enabled it
Intel speedsteptech =======================>disable
intel C-stateTech =========================>disable
cheers
Damn didnt notice your chip on first read :D // lol i think that he just edited it in the text after i read it first
that is pretty high vcore for that clock :)
He's using ASUS P5Q PRO so no floppys needed, If you just own usbstick you can update it whit ASUS ezflash trought bios ! And newer than 1402 bioses you can just us ezflash and flash you bios from harddisk!
I recommend to use Asus ezflash if you just own the Usbstick!
Please, don't say stupid things like this without properly reading the thread. By properly reading the thread you will find my mBIOSes actually;
- Increase FSB limits for most people
- Fix pull-ins
- Increase memory compatibility
- Custom P6 CPU table
- As a result of all of the above most people get better OCs. In the case of CPU clocking a lot say they can use less vcore for the same OC vs. vanilla BIOS.
I have found out that my TWIN2X4096-8500C5DF isent working on this board. As a single stick they works fine both of then. As Dual none of them :S I have tryed some other ram in it with dual mode and it works fine there. So my question is. Wich ram should i buy to my P5Q Dlx ? The QVL dosent have quite many 4GB kits. What is a safe buy for me ? I want my new comp to work /cry
Try the latest mBIOS if you haven't already, it may resolve your issue.
I have tryed the 1306m with no effect :( Should i go for the 1406m ? I have 1406 atm. This is really annoying for me and Asus support is just Dumbasses....
Btw. Ket i have added you to MSN
thanx for all the suggestions guys, i will try to edit my bios, i don't think i can go lower on the vcore bios voltage! if i do, i don't think the mobo POSTs ...i want a max cpu speed of 3.6 :D while using the least amount of voltage! course everyone wants this combo! i ran prime95 for only 30mins and passed so its pretty good at this pt.
not sure if i want to flash the bios tho, im kinda nervous doing that
Not defensive, just hate misconceived information. A newb reading your post and not the entire thread could easily interprit things incorrectly and as a result keep battling with an issue an mBIOS can fix.
