Originally Posted by
ChrissTi
Here is my setup:
Robust Graphics Booster: Turbo
CPU Clock Ratio: 8X
CPU Frequency: 3.616GHz (452x8)
CPU Host Clock Control: Enabled
CPU Host Frequency(Mhz) : 452
PCI Express Frequency (Mhz) : Auto
C.I.A.2: Disabled
Performance Enhance :Extreme
System Memory Multiplier (SPD): (2.4B)
Memory Frequency(Mhz): 1085
DRAM Timing Selectable (SPD) : Auto
****** Clock Driving and Skew Control ******(?????)
CPU/PCIEX Clock Driving Control: 800Vmm
CPU Clock Skew Control: Normal
(G)MCH Clock Skew Control : Normal
******** System Voltage Optimized ********
System Voltage Control: Manual
X DDR2 OverVoltage Control: +0.60V
X PCI-E OverVoltage Control: normal
X FSB OverVoltage Control: normal
X (G) MCH OverVoltage Control: normal
X MCH Reference Voltage Control: Normal
X DDR Reference Voltage Control: Normal
X DDR Termination Voltage Control: normal
CPU VOLTAGE Control: 1.5375
Normal CPU Vcore: 1.5375
The system is very stable on air.
By simply letting - DRAM Timing Selectable (SPD) : Auto - the bios configures the memory timings.
By modifing Performance Enhance to Standard, Turbo or Extreme, it modifyes the chipset and memory timings to have less or more latency. Lower the latency (Standard) to gain system stability.
I have 2 different dual channel memory kits 2x2GB, and because of that I could not overclock them as much as I wanted. I've tested with one dual channel kit and managed to go to 1200 DDR Mhz (600Mhz real), stable, on air.
