My bro brought me a new chip today.
3500+ Manchester CDBHE 0602UPMW 1400016A61056
Another attempt to steal your WR, stunni;)
Spending a couple of hours in this thread every day [check]:p:
hehe worldrecord mafia in here :D
:lol:
Trying to go over 3.8 ghz @ 3700+ [check]
Trying to go over 3.8 ghz @ 4000+ [???]
I see you have to go a long way, bruce :D
Dont touch that 3500+ result if yes i will come to norway.....with gianni :lol:
i'm in! our team has a own privat jet ;)
http://octs.ripping.org/octsair.jpg
btw: i've got this damn non-fx 32m wr!!!
The 4000+ 0631APMW WILL be tested next weekend!:D 3.8ghz powah I hope. I've already had 2 BAD 3500+ manchesters, I hope the 3rd one will be nice. 0602 was a pretty good week I remember;)
Since the last session was so short, this one must be alot longer. Friday night ---> Sunday night:D
don't thinkn about 3.8ghz :D
0631APMW
1495648G60593 => obarok => 3375MHz prime air
1495648G60601 => gianni => 3578MHz
1495658G60075 => gianni => 3541MHz
1495658G60279 => stunni => 3869MHz
1496338H60387 => obarok => 3200MHz @ 1.5V prime air
1496358H60520 => ebay
1496358H60667 => bruce
1496568G60071 => gianni => 3669MHz
1496568G60677 => gianni => 3778MHz
1496568G60862 => bruce
1496578H60222 => gianni => 3787MHz
1496578H60453 => ebay
1496578H60519 => ebay
1496578H60866 => ebay
1496578H60736 => selloutking => 3200MHZ @ 1,45V ohne HS prime water
1521468H60496 => obarok => 3100MHz @ 1.52V prime air
had to take a photo of the 32M run (thanks to mr. coldbug)....
http://bastel-gianni.ch/overclocking...sec_sd4000.jpg
to compare: 3705mhz cpu, 265mhz ram
http://octs.ripping.org/sd4000_32m_3705.jpg
and my very fastest run freezed at loop 24: with 3723mhz/267mhz, at the end of this run there would be a sup 19min40sec time... :(
http://octs.ripping.org/sd4000_32m_fastest.jpg
Great gianni ;)
The overview of that 0631 APMW is nice I should do that for all the cpus I had and that you two had.
Tested my last A64, not really good, coldbugs at 350HTT, but can't do 1M higher than 3150Mhz (no matter what voltage or MP)
http://valid.x86-secret.com/cache/272969.png
http://valid.x86-secret.com/show_oc.php?id=272969
Thats right but there are also some cpus which dont want do go high.
@ massman
Stepping ? The 20./21. week 2005 was one of the best at E3.
Mach2 cooled, -30 I think.
Should I get dice for better performance?
dice is useless... this chip is crap ;)
Hehe you have the same cpu like mine:
ADA3800DAA4BP
LBBLE 0521 DPMW
Z711392F50046
the following settings i could get with this under my single stage:
max Vcore: 1.824 v @ SLI-D
max HTT: 387 mhz @ SLI-D under SS !!!
Validation @ SS: 3460 mhz @ 1.824 v
Validation @ cascade: 3570 @ 1.808 v
I have no validation file of cascade because i tested the cpu and after that i thought that it would be the cold bug so that the cpu dont want to get so high. later i take my ss and the results wouldnt better and i got only an validation of 3460 mhz :(
Cold Bug: -37c/374
Your chip wont be better than mine :(
@ bruce
the chips before year 2005 will not go high, 0513 would better, best are 0517 to 0521. this will be for all !!!! winchesters. best stepping is 0517 spmw by the way, 2.7 ghz @ prime @ default vcore was doing. but i never found that chips in the past.
By the way to ending the weekend i got another one WR !!!!
3500+ Winchester @ 3238 mhz @ 1.776 v w/o heat spreader !!!
hehe congratz! not long and there are really no more wr's to crack. :D
Look at the validation there it is written in the header.
CBBFD 0432 TPMW
Look at this:
with HS: 1,392v/-32°C --- 1,520v/-24°C --- 1,776v/-4°C --- 1,808v/+14°C
w/o HS: 1,392v/-38°C --- 1,520v/-33°C --- 1,776v/-26°C --- 1,808v/-21°C
all temps are im idle....really amazing the difference.
hehe are the worst mounted ihs ever :D
I think so :D
My WR X2 4400+-chip was bad as well. I think the IHS almost had no contact with one of the cores at all! One core had 35c load on water cooling and stock voltage, the other one went straight to 60c lol. I shut it down, it really went DIRECTLY to 60c in 0.1s!
My 170 is awful as well, 15c core difference. That one will be popped next weekend:p:
Found a venice 3200+:
ADA3200DAA4BW
NBBWE 0602APAW
Z878487A61283
Should be a good one, no?
