Originally Posted by Rysing_Phoenix
That doesn't seem to work for me. :rolleyes:
After I got a stable OC set up, I then tried using IDCC to make tweaks. When it fails, I turn PSU off for a bit. Turn back on and still no POST. Have to go for the jumper. :( Am I doing something wrong?
Atleast I'm running at 3.6ghz on air though. :woot:
Temp is lil higher than I like so that means I won't try to go higher, which is slightly disappointing. Damn the B chips.
Also, is there any way to control fan speed in the bios? I'm using a 3 pin fan and I just want it to go full blast (or even up it's voltage, since it's silent :P). I tried turning off auto fan management in bios but that didn't work. I finally found the setting in IDCC to max it so I guess it's okay.
The other question is I've read some people are having success with Memset and recommend lowering tRFC from 42 to 28 or even lower. When I tried that my system "zaps" and then it wont post. I tried a few times with setting as high as 28 with no success. Do I just have crappy-ish ram? I have the OCZ OCZ2P800R22GK platinum rev2.
Thanks for any help in advance. Lots of good info in this thread!
