Hi RubiconX3, can you please let us know your bios settings (VCore, Vmch, timings, ie, relevant o/c settings etc) and if possible, a screenshot including Guru showing mobo voltages (just like I did above with mine)?
Originally Posted by Sicness
Nice to Hear Sicness !! ABIT in 1333 strap !!! where you get info ?:) :) :)
Sure ill have to install Uguru. Give me a min
Well i had problems with Uguru last time and uninstalled. Same problem this time so i had to uninstall again. Soon as the computer starts and loads uguru it shuts it off imediatly.. crap Anywho i got everything else
401 FSB
1.6 vcore
1.7 MCH
1:1 Ratio
4-4-4-8 timings
http://rigshowcase.com/img/281aOTVr/7170.jpg
Thanks Madellga, but no luck here. Could you send me a dump of your RAM? I'll really appreciate it; this mobo is gving me a major headache :(. Thanks.Quote:
Originally Posted by Madellga
Vcore 1.52v
Vmch 1.87v Pretty uncomfortable
Vdimm 2.45v 3 3 3 4
Orthos 8 hours and it was another dead cmos battery case, wat's with Abit?
http://img245.imageshack.us/img245/1897/orthos36rn9.jpg
Hmmm what are the symtoms of a dead battery lol? I might as well replace mine while im at it
Everytime I turn off the pc and the power, the settings in the bios reset to default the next time I boot up.Quote:
Originally Posted by Rubiconx3
Ahh obvious lol. I dont have that problem
Anyone had any RAM probs with this board?
My Super TalentT800UX2GC4 2Gigs went south today,looking back at my so thought hard drive/install probs,what was really happening was my sticks were dying.Shame really cos ive had them at 500mhz on the 4/5 divider before :(
Having mad problems with my OCZ PC6400 Plat. Rev. 2. Interestingly, I'm running my OCZ Value PC4200s at PC6400 1:1 divider with 5-5-5 timings; they even did 5-4-4-9 at PC6400 speed but were orthos unstable in Windows. Funny that the older technology overclocks better than anything I've seen recently. The value RAM even run at 430 FSB on my Asus P5WD2-E Premium.Quote:
Originally Posted by thebeast
Something I do not understand with this board is that the PCIE frequency seems locked at 100 and would that not cause stability issues with the OC:confused:
I bet that only your settings in the Guru section of the BIOS are reset, everything else stays the same. Correct?Quote:
Originally Posted by Iceflight
i have the abit from some day...today i tested the mobo for few minute and the results are this:
boot @ 410*6 - win 451*6 vmch 1.8V - ram 1:1 timings by spd autoset 4 4 4 12
http://img104.imageshack.us/img104/9983/45018as9.th.jpg
boot @ 430*6 - win 465*6 vmch 1.9V - ram 1:1 timings by spd autoset 4 4 4 12
http://img261.imageshack.us/img261/9103/46519rt9.th.jpg
boot @ 440*6 - win 470*6 vmch 2.0V - ram 1:1 timings by spd autoset 4 4 4 12
http://img264.imageshack.us/img264/6720/4702mz9.th.jpg
boot @ 440*7 - win 470*7 vmch 2.0V - ram 1:1 4 3 3 9
http://img264.imageshack.us/img264/5142/47072pz4.th.jpg
cpu liquid cooled and mobo stock....i raise vcore and vdimm vountarily to avoid problems...bios 1.2 official...max boot to 450 fsb, i haven't tried more :woot:
that's exactly my case.Quote:
Sometimes it's this way, sometimes everything resets to defaults including ram timings, etc...:slobber:Quote:
No one ?Quote:
Originally Posted by palese
Does PCIE frequency even matter?
After preparing my mobo for benching, I did some VERY QUICK tests.....Propably I'll get more out of it......I even reached 489MHz 1:1 but I was in a hurry and I quit....Rams are 2 x 512MB Corsair 8000UL with Fatbodies chips.....;)
Testing mobo under esdee's cascade for fsb.......:)
http://www.thelab.gr/images/Hipro5/C..._3_2_1_png.png
Just some quick runs.......:D
Yes it helps to get more fsb.....;)Quote:
You want it locked at 100.
This board locks it at 100. I flashed back to bios 1.1 as PCIE is still in bios before 1.2 and adjustable or it appeared to be, but anything over 100 and the system would still freeze like it does from windows.Quote:
I believe 110 is the proper setting for OC'S, I'm@ 3.6 and oblivian crashes on me but when I go back to stock speeds all is well with the game. Isn't this directly related to the frequency of the PCIE as it can not run at higher clock speeds with out the proper frequency adjustments as the system clocks go up?
I'm sorry I am just trying to under stand this:confused:
My understanding its automatically locked @ 100. I run mine like in the specs in the pic above. Have no problems
Nubish question:what would offer a 1333 strap?Quote:
If we get the 1333 strap then we should see 600+ FSB clocks. This would be great for low end processors with small multiples.
Not very pleased with these board right now. I have put As5 under the NB block, and mounted a 40mm fan for better cooling. I can now go up to 445fsb at 2v to mch:n. With lower multi no can do either. Trying some divider, HAHA suck that...400fsb and 4:5 no boot. I thought ABIT was good stuff but for me it`s crap right now. My asus p5w dh was better with higher fsb and dividers......
