no I can'tQuote:
Originally Posted by dogsx2
no I can'tQuote:
no optionQuote:
Originally Posted by kiwi
Add /numproc=1 to the boot.iniQuote:
Originally Posted by coolaler
This is your option, good luck with it ;)
Explanation: http://support.microsoft.com/default...21120121120120
i would love to see it with frost.. still the stock vcore but it has to give more :D
That's great info Alexio, thanks for sharing.:toast:Quote:
Originally Posted by alexio
Somehow I think it is not the same as to disable it in bios. But who knowsQuote:
Congrats to "old man and dog" you are a great team :D
coolaler - thank you for sharing all of your amazing results. :clap:
And here is the picture, you can also set 'maxmem' in this area as a tweak. To get here go to: Run --> msconfig --> BOOT.INI --> advanced option
Safe and restart after setting /NUMPROC= 1 ;)
http://img.photobucket.com/albums/v3...Hunter_001.gif
Good luck coolaler, it should help atleast somewhat :)
How come Fugger needs 1.65v to get 12s in Spi1M@4Ghz and you only with stock vcore@3.8Ghz get the same score?!Quote:
Board?! Ram?! What else?!
BTW....Great job!!:toast:
both were 3,9 GHz :DQuote:
Originally Posted by JohnMike
4GHz was just screen shot
You mean, fake?!Quote:
Originally Posted by yotomeczek
NoQuote:
But it was just CPU-Z nothing more (Pi or some bench)
Amazing coolaler! With slightly more vcore and you will bench at 4ghz :D
welldone:banana:
coolaler :clap:
cheer for five world reconds:toast:
Damn!!! Go to bed and wake up to this! Conroe is already a monster and adding Vcore just makes it that much nastier! I want one with fries please :fact:
Welldone m8. Seems like you have a lot more to give
Coolaler has B0 ConroeQuote:
FUGGER has A1 Conroe
See the difference man :banana:
coolaler got better performance from his board then fugger gets from his and A1 will be the revision for the retail chips I believe? So there's not a big difference there.
I mean only OC'ing:Quote:
Originally Posted by NiCKE^
3.0Ghz @ Air @ Stock Volts with Coolaler's A1
and 3.3Ghz @ Air @ Stock Volts with Coolaler's B0
And 3.8 @ Stock Volts + LN2 is very impressive
compared to 3.9-4.0 FUGGER's @ max vcore IMO
BTW B0 (or even B1) not A1 will be for retail chips, so ...
thank you!I am very appreciate:toast:Quote:
But does that stop the 2nd core from putting out heat? Prolly not...
But if one core is weaker and the other core is better this trick can help, except if it's like my X2 where core 0 is the weaker core
Guys don't FORGET that coolaler is with LN2 cooling and FUGGER is with a Vapo single phase change.....;)Quote:
Originally Posted by maratus
Way to go coolaler....:) :toast:
But still hipro, coolaler got stock vcore and fugger got 1.6v ;)
But still FUGGER is with -35*C and coolaler is with -190*C........:DQuote:
EDIT: I was with the Dothan at 3600MHz with the Prommie and R410 gas and at 4200MHz with LN2..... ;)
I agree with you on that. I'd take Coolaler's cpu any day.:DQuote:
