Pushing it a bit higher.........
Well done as usual h5:thumbsup:
DAYUM!!!!
Something I dont understand.. Sandra said I was 2.5-3-3 2T when in fact I was 2.0-2-2-1T in BIOS... Am I missing something or was my Mobo toast from the start??
No , S-Sandra IS rigth........When you pass 140MHz fsb then automatically the Mobo puts the Cases at lower speeds whatever you do......You have to use WPGREDIT or a Modded bios to fix that....... ;)Quote:
Originally posted by K_2
DAYUM!!!!
ok gotcha.. Did you use Modbin6 for the bios modifications??
No.....It doesn't work for AWD bios.....Only for BIN......
UPDATE---UPDATE.......
New score.....
Pi-fast.....
Super Pi.....
......and ALL these Updated benchies were done with the Pentium4 2.4GHz @ xxxx
Hipro5: Superb benchmarking!!
I'm gonna disconnect my 4600 from my system, and focus on doing some cpu/fsb overclocking for a bit ;) I did a 40second super_pi two days ago but my fsb wasn't maxed. In any case, I dig hexus pifast more. I'll try runnin that @ ~233mhz fsb and ~2650mhz. That combo should get me 55s hexus pifast methinks. ;)
Thanks sysfailur......I have a Geforce4 440MX witch can handle about 90MHz AGP.....Not bad...!!!...Quote:
.....and tommorow I'm changing CPU again and putting in a P4 3.06GHz to see how it does,but.....not for Memory Bandwidth..... :D
I think I gave the wrong impression. :P (Just to clarify) the reason I'm disconnecting the 4600 from the loop is cus the heat from the 156w peltier along w/ the other pelts really kills my ice in my resivoir... If I disconnect the 4600 I can get more time to OC w/ my mobo/cpu. I wasn't disconnecting it cus the 4600 can't handle speeds. I lock mine @ 90mhz and put 1.7v into it. 93mhz gives me some glitches but 90mhz works fine heh.Quote:
I can't wait to see your results w/ that p4! 4ghz maybe?
Now I understood.......As for the P4 , yes 4GHz+++....Quote:
Pics, Pics, Pics :D
I'll change this P4 2.4GHz with a P4 3.06GHz and I'll post .......I just got the digicam from my friend..... ;)
I wonder what the mods are like for the 8INXP. SINXP and P4G8X..?? I have all three coming to me Fri :D
Will have to test and see how each performs....
And thanks for the pics hipro5, that is very kind of you to do this for me!
Just got the 8INXP and SINXP in now.. what should I test first??
Take a "taste" of the pictures.....I'll post them ALL with in a small Review I prepair for Modding an ASUS P4G8X Deluxe......soon..... :D
....and......
Right on!! Ya think you can take a look at the 8INXP also??
In one word.
WOW.
Thanx for giving me inspiration :)
Thanks man........and you're welcome..... :D :toast:
UPDATE........
Tweaking and Modding again with the Pentium4 2.4bGHz.......
do u think your gonna hit a wall anytime soon? this is great. :toast: hit 6k!
