FCG Do u need some help with the PHASE unit ? Ill come around and help you quickly... be there in 5 mins :P Let me OC this 2Ghz past 10GHZ ! lol
Edited for inappropriate language
no probs mate... btw, FCG: can i help u dispose that conroe crap u have there? ;) ;) ;)Quote:
Originally Posted by ORCBEAST
LOl class man class :DQuote:
Originally Posted by cyrixMII300
Nothing like trashing up a good thread.:slap: Hopefully a mod will clean it up before it gets put in the Inquirer.:D
Thanks FCG, this is what we all have been waiting for.:)
well guess we'll all be double famous then... just kidding. sorry mate. here it goes :slapass:Quote:
Originally Posted by dogsx2
Keep it on topic and the language clean. I won't ask again.
Thanks.
OH Man so close to the WR 13000+
AMAZING ! FCG hope u aint mad for crapping in ur thread abit..
THX ! Its 3:20AM here ... :toast:
Wow....scores like a Presler on the CPU tests (though still not OC'd much at all), but scores like an X2 on the GPU tests (better it seems actually). Best of both worlds (and it's still not OC'd much at all, neither are the GPUs)!
is there going to be a conroe E6400 2.13 with 4mb???
http://images.dailytech.com/nimage/1...oe_pricing.jpg
show's here its only 2mb..:confused: :confused: :confused:
From everything I've read, the retail 2.13 (E6400) will only be 2M cache as your chart shows. FCG has a 'special' chip. I assume its an ES. The E6600 will the chip to buy... er, well... that or the 3.33xe
For me will be CNR E6600 for 316$ :banana:
Better wait for better MOBO :slapass:
Me too on that E6600. The mobo FCG is using seems fine. 2.72 so far. Is all goes well, he'll set every record tonight. We shall see.
Man, I wanna see '06 scores on CF !!!
It's only a few posts up :confused:Quote:
Originally Posted by vanquish
Hmm, CPU Scores were a bit surprising to me. I thought itll be touching 3000.
Hmmph.
Nice job FCG!
Any idea when Asus Mobo's on the (D975XBX are supposed to be out?
Great stuff FCG. Very impressive.
Have you or FUGGER got hold of a 2MB Conroe though?
Would like to see how they compare against the 4MB ones.
Me like other I presume would be getting the cheaper 2MB versions.
Thanks!
You'd think with it being an ES that it would allow multipliers above 8x?
Surely it would be a lot easier to push it higher if you could just leave the FSB at the default modded 333 (from 266) and crank up the multi.
Does the Intel board not multiplier changing? :(
I don't think the bad axe has many overclocking options--unless you have a EE.
I want a E6700. Looks like the 10x multiplyer will pay off!
how doese one see the revision of the mb ,doese one have to open it or is it on the box? doese it only show the version on the mb? and its 304 we are looking for right?
304 is the one.Quote:
Originally Posted by vanovich
From what I know its not shown on the box, you'd have to open it and inspect the motherboard to be sure.
Originally Posted by lapdog
All the OC options can be unlocked using Intels Integrator tool kit (can download from Intel site)
But you need hardware mod for higher vcore/vdimm, am I not right?Quote:
Originally Posted by cupholder2.0
It has vcore up to 1.6 and vdimm up to 2.2 as it is. i can see a vdimm mod necessary, but vcore is probably enough for conroe (1.15v)
Originally Posted by Durzel
The version is shown on the box sticker.
My box sticker shows the string AA D27904 - 302 in very large lettering on a sticker with barcodes on the side of the box. The last 3 digits denote the board revision, as mine is 302 the new ones should clearly show 304 instead.
There is also a small sticker with the same string and barcode stuck to the center of the board itself.
