I'd like to buy it, but my money is a factor. Someone is going to be lucky when they purchase this.
It's for me :D
barg - not baraQuote:
Very "small" vac .. only sth like -0.97 bara... LOLLL
Bara is absolute and the lowest number is 0. Barg is relative to the atmosphere and can go negative.
Yes, those rotaries are known for noise. But reciprocating compressors are not always quiet. My friend Shivani had worked on an old condensing unit (for a commercial install IIRC) that had a 3 ton Brysch variable capacity compressor (which has a crankshaft position sensor and a solenoid that can hold open the suction valve to "skip" cycles). She said that at anything less than full load, the unit sounded like a motorcycle!
Hi
Just before sending unit to it's new home (CornerJack's home :D ), I've made last test with it - on "ancient" ;) A64 Venice @3194 Mhz/ 1.78V :toast: .
http://www.members.lycos.co.uk/piotres2/rotago/1.jpg
Idle in windows .
http://www.members.lycos.co.uk/piotres2/rotago/2.jpg
Stress during MotherNature in 3Dm03 :) .
http://www.members.lycos.co.uk/piotres2/rotago/3.jpg
DFI NF4-D bios :toast: .
http://users.skynet.be/fb331210/pio1.jpg
Unit and some other stuff (SLI containers + CPU container Ln2/DI) made by me, in Jack's home :toast: .
Regards
Peter
Nice performing SS! Baker made some nice R-22 rotaries a while back, great performers :)
