ryankenn, i actually PM'ed t024484 about that...
But this would have me shorting Point A to a point right next to it, AND then to ground. Most of the mods I've seen only go from Point A to ground, and aren't shorting to the pins next to it. I'm assuming it will work either way, just curious.
when looking here:
http://img87.imageshack.us/my.php?im...y8ei7sh3no.jpg
Looping over B is done to get 1,4v. If you also hit B then you get 1,50v. Doing only the "purple" line wont do anything. You need A to hit the groundpoint for 1,4v.
Dinho, OVP is in the ISL chip. If the chip dictates 1,2v, the ovp will kick in at 1,3v. But if you change the ISL chip to 1,4v, then the OVP will kick in at 1,50. Same if you go with 1,55v, OVP will be at 1,65. By modding the ISL chip table you simply bypass the ovp by making it output a higher default current.
Did you do the "resistor k" mod? (see post 1 and 2).
