Tried them out with dry ice today.Quote:
Originally Posted by PoL
CABGE - Coldbug at -33º (no >255Mhz)
CCBWE - Coldbug at -36º (no >263Mhz)
opt 146 CABYE -> -55° -> Max Htt 270
http://www.membres.lycos.fr/boblemag...40fpmw/201.JPG
CABGE 0536 no coldbug down to -30 idle. Clocks past 300HTT fine at this temp. :D took me long enough to find one! (cheers njkid!)
Opteron 146 CABYE, idle -27C, load -5C, bugged at idle temps and htt >325
Opteron 146 CABNE 0544 EPMW, idle -28C, load -4C, bugged at idle temps and htt >305.......
This su*, need unlocked multi :D
From 3 chips under phase/dice, 2 were bugged but this happens only above some HTT :slapass:
Anyone know how an 146 CABYE 0540 FPAW will fair? I've just ordered myself and chilly1, but had it overcharged for higher temps and hopefully no coldbug.
My chip is no longer coldbugging over 255 HTT/-26C, it's more like 290 now. In fact I'm typing this with it at -30C @ 270x10. Why? Different RAM settings. It's not completely gone by any means but it has receded to a point that's more managable. Setting a lot of stuff to auto really helped. ;)
I thought only Drive/data strength might help. What else? I have tried many settings, also auto.
I set drive/data strength 3/auto. Trc was the other biggie - manual at 7, auto at 15. 7 works for some ppl with HZ but not me.
fx 60 -->> CCB2E 0536 WPMW very cold bug :(
I have to agree with rekin.....FX-60 CCB2E 0536 SPMW, worked at 3.4 for about 20 minutes, rebooted, will not boot at all now. -27, then NO BOOT at all even after overnight wait.
Also X2 4800+ CCB2E 0536 WPMW also cold bugged. -25 bios(250HTT) Ok @ stock to 238HTT
We need to stay away from CCB2E's of any kind it seems like. Not for aPhase although descent on water, both chips ran 3 gigs on water
Welcome to XS Rekin and Kendragon:toast:
XXX2E really sensitive with evap. temp around -37C.
FX-57 CABCE 0530 BPMW no cold bug under dice, -51 core. Tested HTT to 350 :woot:
thank's Dumo :)
after testing my FX60 cold bug at -17° ; I put a copper plate for avoids cold bug enter the evaporator and the cpu.
resust: full stable and booting good at 3.3ghz
sorry for my bad english because france power :D
Could you elighten us on the copper plate? I do have an extra A64 heatspreader(Damage 3500+) i may be able to dremel the edges for that purpose. Cause I'm sure even with a plpate 3.3+ is capable on mine, or I am gonna RMA it. Was shipped 2/23/06 ZZF has the 15day so friday next week can still RMA.
And thanks for the welcome Dumo, you'll see me sometimes on Bleedinedge.
CABYE 0528GPMW FX57
on 2 stage ethylane cascade -105 idle -98 full load
core @ -63*C can boot up to 245Htt
once on multiprocessor in windows @ 208 from smartguardian (-48*C) can do more than 280Htt, havent tested more
on single stage -25*C more than 350htt is possible as tested
CCBWE 0546 MPMW = Opty 165 dual core
POSTs @ -50 (evap temp) and boots and benches @ -27C cannot really test below that.
HTT tested up to 350 or so fine. has x11 multiplier unlocked. :stick:
No cold bug with : Opteron 175 (310X11) @-45 (smartguardian) , or -52 evap .
CCBWE 0530TPMW
An Old 4000+ KABYE dunno week and so on was pretty nice @ kaskade -80C evap -47C core no problems.
146 opteron:
CACJE 0601 GPAW -10Core temp buggy, doenst start in win
max.HTT not tested, yet
3700+ san diego:
KAB3E 0548 BPAW -15C core temp buggy, doesnt start in win
max.HTT, 325x11 no problem
MPS Multi cpu helped also more Volts to get to -10 or higher.
seEn
opterons:
146 cabye 0542fpmw at -15
148 #1 cabye 0542fpmw at -10
148 #2 cabye 0542fpmw at 0
180 dc - ccbwe 0530tpmw - not cold bug on my SS
athlon 4200x2 cdbhe 0522tpmw not cold bug on my SS / d.ice
Opteron 148 0543 CABYE FPMW
My CPU reports very very wrong temperatures, swinging from -30C to +8C within a few seconds. The hardware monitor on my DFI NF3 Ultra-D is very wrong.
http://www.pclincs.co.uk/Forums/atta...=&postid=86822
The evaporator face is at -40C and the back of the motherboard is at -20C so i would assume a core temperature in the -30C region as im running low voltage.
I have not encountered any "cold bug" with this CPU.
Tom
that's nice cause I have a modded LS on the way and have the same stepping CABYE. It already runs 3.0Ghz on air!!
CDBHE 4600+ Fun @ 1:1 TCCD:
http://img64.imageshack.us/img64/7049/11x3008jj.jpg
OPB's or you got one too? :eek:
Originally Posted by s7e9h3n
