i can re-ghost it as soon as i find the Norton Ghost disk. Thanks for the explanation, sorry for the slightly OT.
http://home.mindspring.com/~kvits/im...0-%20Small.jpg
Thanks to ozzimark for the recommendations on the memory timings. Could not reach 4.0ns, but still my SPi times dropped by ~35 seconds on each core. To ozzimark :toast:
nice CPU kyle
make that cpu respect you
Wow, this exceeded my expectations, given that reviews said the chips they tested weren't very good overclockers at all
Wow this is going a lot better congradulations my man :toast:
Now can you tell me what was the problem before...What was limiting you at 3.2Ghz?
You were able to push your ram higher i realize but what else were you having problems with that was limiting the cpu. Didnt give too many details o nthat. What did you end up changing for a higher oc.
See AFI I told you this guy can get 3.3+ out of it :D
Show us some 3DM05/06 action w/ those 7800GT SLI on 3.4ghz it should be able to pass...
Push a bit more and get a super tweaked OS and you might break into the 22m range!
I didn't think he could do this high at first becauase of the MASSIVE difference between prime on two and 1m on one core, but it seems he was just warming up there :D That's a killer chip for sure, unfortunate that it cold bugs so bad.
Damn, and I'm thinking of putting a 170 in a Mach1. What voltage gets you 6C?Quote:
Here are my 3DMark 05 and 06 scores. Looks like I need 512 GTX's to hang with the big boys or maybe watercooling and wait until G71's come out. Running the GT's at 489/1270 :rolleyes: with Artic Cooler 5's and Artic Silver.
After I ran these I think my LS decided to die on me. I don't know what happened, but my pc froze and I rebooted (thinking probably temperature related freeze or something), but as it posted the case speaker is like a solid beep and the pc starts to hang. So I hit the power supply switch, motherboard shuts off, LS still running so I pull the power cord and LS is still running :eek: .
I had to leave for dinner so I left thinking maybe the starting cap still had juice and would just shut off after a little while, but after I came back (several hours) it was still running. So I pulled my bottom GFX card to disconnect the USB cable going from chilly control (cc) to motherboard and as I pull out the GFX the LS shuts off. and starting messing with the cables on the cc and the LS starts up and motherboard posts, I load bios, but then it shuts off. I look at the LCD it's lit but blank. I try making sure the connections are secure and it kicks on again, but this time when it shut off I think something bad happened :( because now none of the lights on the cc board come on and the LCD won't light.
I have tried reseting the cc, but no luck. I guess I will have to run air now and get in touch w/ asetek in Denmark. After I see what they say I might just send it to Chilly.
Lets hope I can resurrect this thing I've only had it for a week. :slapass:
If anyone has any clues let me know.
Ummmm...you pulled the plug on the Vapo and it continued to run for a couple of hours? lol...That's not possible in any way, shape, or form. You sure it was the plug from the phase unit you pulled and not the TV cord or something? :p:Quote:
Regardless, you've blown a fuse on the vapo. Go get yourself a few replacements and stick a new one in. Should be up and running right away.....
your cpu score is only 100 short of king pin 06
http://service.futuremark.com/compare?3dm06=57449
Believe me when it happened I was in shock when it kept running no plug to it. I should've taken a picture, now I sound like I'm crazy.
You're the one that said it.....:D ....Kyle, what's the batch code on your cpu? Do you remember? It's the last 4 numbers on the 3rd line....thxQuote:
Wow wtf :lol: Sorry to hear about the vapo :( Nice scores and nice mems on the GTs. Vmod the core and you'll kill my scores!
Check the vapo's fuse inside.
I will look into it, I would like to see higher core clock.
@ Dumo: Could you tell me where this fuse is and possibly the size and amperage? I am going to start taking this thing a part tomorrow and I would like to know where to look. Thanks
The horror... I'm on air. Time to call Chilly and get a back up.
SO can you tell me how you managed to get 3.4ghz but was stuck at 3.2 beofre...What did you wind up changing?
Send it to my man chilly1 he will fix you up. They are swapped right now though might take some time :D Oh and get the compressor, evap, and chill control v2 changed while your at it!
Get yourself something along the lines of a Mach2 compressor. The vapo compressor has less capacity and is wimpy compared to the one used in the Mach. Temps on the compressor may not go as low as the vapo's (but not by much), but holding temps should definately be better.....Quote:
I just noticed your FX60 is @ 262 x 13 on LS very nice. :toast:
http://www.majorgeeks.com/download4083.html
that should help you tweak
@ crash: I was just stuck at 3200 for stress prime, but once I got the time to fool with it some more and learned how to run dual SPi I was able to show higher numbers. I know I lowered overvolt one step down, but it really seemed to become more stable after I got some RAM settings from mzdcpa b/c everything I had tried would not go over 250 (though I am still limited to about 270). The thing that helped I think was drive strength 7/3 b/c all of my other settings were pretty similar to what he already had. And ozzimark's suggestions really helped my speed, but I was already stable.
But seems to be a volt (to help control temp) and drive strength issue. The chip just seemed to get better, but maybe it was me getting acclimated to using phase. I busy pulling apart this LS and trying to figure out why my Expert is acting up. First the USB ports don't want to work and now it won't post (hoping it's a ground to the mb tray) otherwise RMA and off to buy a new one or use this A8N32.
@ stephen: Yeah I would love some more stable temps under load. The LS starts cool then the temps skyrocket underload. This sure would make finding ideal settings easier. I'll PM Chilly to see what he recommends and how busy he is. Maybe he can bump me to the front of the line I mean I got WR's to break :D
