Hicks
That's a pretty weak Socket A heatsink :stick:
Whoever got the stock Opteron HSF on the GTX - can you shop the zip ties around the back?
Hicks
Im not thinking about a single 3DMark test at 1,6V, but gaming for hours?
My temps arent the problem. But should I be aware of the high voltage?
Would the mod work on an x1900 in either one of the PCI-e slots? I'm not totally sure.
http://www.planet3dnow.de/news_images/A8R32-MVP.jpg
anyone tried to mount a CNPS9500 Cu on their vid card :rolleyes:
THAT would be a sight to see :)
P.S.
Probably have to make custom mounts (I thought the 7500 would rip out the
gpu frame :p: )
Nightcrawler appears to have, judging by his sig and avatar hehQuote:
Originally Posted by topaimz
http://www.xtremesystems.org/forums/...ine=1137869217
:clap:
Here pics of my moded X1800XT.
My results after 30min. of Ati-Tool Cube spinning.
Zalman VF900 @1,5V @710Mhz = System freeze @90C (19C Room Temp)
Zalman 7000 @1,5V @710Mhz = 68C (25C Room Temp)
:banana:
http://img288.imageshack.us/img288/8...03096ze.th.jpg
http://img284.imageshack.us/img284/3...03106uq.th.jpg
Can i put a 7000b full CU(745g) or i have to put the al-cu(445g) version on my 1800xt.Because i have a 7000b full cu so...i d be happy if it work! thx
so u guys are just using the mounting from the vf700 to fit the 7000? i got already a vf700alcu might as well get the 7000alcu or what others are also compatible with the vf700 mounting?
Socket 939 mounting holes almost line up exactly, as shown by JuanFlaiter
ya i saw that but thats on a nv card, ati has different spacing, but i see up there that it fits ati alsoQuote:
Originally Posted by couppi
