how the &#^@#(#$^ did you clock that GFX card so high..........you're an animal hipro
do a few more runs i'm sure you'll get there............is that the max you can bench that Dothan :p:
:eek: SOOOoo Close. lol, just.. a .. little.. faster... (mexican accent) you can do it!! (/mexican accent) Lol, good luck Hipro5.
great, now get an 1800xt and release the MAXIMIZER!!!
I had it in a good run BUT Nature froze.......:(Quote:
Originally Posted by dinos22
Yes this is the max I can bench with the Dothan under cascade...It needs LN2 for more......This CPU just loves the cold....Every -4*C I gain about 30MHz out of it..... :)
Originally Posted by Revv23
:D :toast:
I'm coming Vince.....:D :toast:Quote:
Originally Posted by k|ngp|n
Than you need -10-15* more down to take WR.Your clock of GTX are unhuman ,especialy ram:)Quote:
Originally Posted by hipro5
We wait:banana:
You need to put some ln2 on that bad boy now!! :)
With the 7800GTX I'm not quite suttisfied about it's o/cabillity under phase....It does 708MHz (voltmoded) on AIR with default heatsink and a DELTA 12x12cm 190cfm blowing on it, 773MHz MAX at -45*C and 791MHz MAX ay -85*C......It should do at least 800MHz+.... :(Quote:
Originally Posted by DStealth
Yes it's Ram does well ..... :)
Next Sunday is the LN2 party here at my place.....Going for 2d and 3d with both mobos: P4C800E-Deluxe and P4GD1.....;)Quote:
Originally Posted by olfen
Amazing clocks Hipro5 ;)
Wich bios do you use on P4C800E dlx ?
:toast:
Very nice indeed . DO you think you can get #1 with the Ln2 or do you think Vince has backups ?
Regards
Andy
Just insane. :O
1024.001 -beta- but it's the same as 1023 final....Quote:
Originally Posted by 200%absolut
Originally Posted by zakelwe
With LN2 I should be about 52000+ with the same VGA.....;)
I don't think that Vince has any other backups coz he was chasing the 51000 marks.....:fact:
BUT he'll bench again.....He's not a quiter, he's real strong and he knows exaclty what he's doing....;)
Originally Posted by G H Z
I'm ready.....for another pm.....;) :D
It did 493xx on air with core=783MHz and rams=855MHz.....;)
nice job hipro :D
I'm cheering for ya hipro!:clap: 52k is quite possible and if anyone can do it, it's you. No backups ANDy, but might bench 01' again with new ES and "hipro-modded" adapter when he takes me down. p4g/dothan/7800gtx is still one of the most fun kits I ever clocked. The retail M chip I used was semi cold-bugged around -140c. I hope the new es from saaya is better and like high fsb like hip's. I'll bench it once then sell it.Quote:
Thanks Vince.......I'll do my best......:)Quote:
As for the LN2 running, I ain't got any experiance at all and I hope it would be a good start.....:D
"It" as in X1800? Well damn I think thats enough air testing for now don't you think? I can do 840/940 on a pelt so -80° should be good for 900/1000 in your hands.Quote:
Lay some ATI smack down on us :D
First off all those scores of yours are just insane...nice battle with kingpin...may the force be with u guys :toast:Quote:
Now u said that your 7800gtx 512 was doing aircooled 708mhz on the core...remember the voltage???
I'm using on my 1,63~1,65 to reach 680 but i didn't check the max mhz on this voltage...i was just turning the button to see what voltage would i need to reach those speed stable!
My vga is stock cooled with a 120mm fan close!
My vdd is still stock voltage...didn't check the max too at stock voltage...i'm working first on the gpu but the mem's are reaching 1890!
How about voltage on the mem's aircooled?
Thks and good luck on the battle ;)
Yes ATI X1800XT.....:)Quote:
Originally Posted by VoRtAn_MaDgE
Voltage on Core was and is 1.79Volts running 3D.......NO more than this EVEN under phase change......
Ram Volts where 2.3Vdd and 2.33Vddq.....Under phase change, 2.4Vdd and 2.43Vddq....It can't handle more than this.....
My X800XT can handle 2.51Vdd and 2.55Vddq....:)
You. Are. Just. Insane... nice scores :)
No prob's with that core voltage with the extra fan? NICE :DQuote:
Got to squeeze this bastard this night ;)
Did u gain anything doing the vddq? how much?
That voltage on your x800xt make it look like a battle car :CTF:
