CF doesn't work for me in '01, it's slower than single card :confused:Quote:
Originally Posted by FUGGER
999 FPS on pool in Nature but final FPS is less than single card.
Bitpower check his sig.
Fugger...lets see some 06 @ 6.0 :) :D
Perkam
I will have a review done shortly on the ram and write up more info on the P5WD2-E.
I was able to push the 955x chipset to 6.2Ghz for Pi and with the 975x I cannot get 5.8Ghz stable on cascade.
I am able to adjust temp quite a bit to fire up ~ -70c and lay on the cold by turning a valve and reach max temp in a few seconds. Hit or miss if I can restart @ -100c.
Now that I am using two video cards I will start using multiple power supplies. The added card might have reduced my oc due to lack of power.
Dual PSU is essential with dual core + dual video cards. Keep the system on it's own PSU. I use an enermax liberty 500 watt for just my motherboard. Hook all your fans and hdd to the video card PSU. Your OC will fly with dedicated mobo power ;)
oh yeah, I would love too see the CPU score on a 955XE, 4 logical threads, 06 can take advantage of 3 IIRC.
It'll be something amazing to witness...I can't wait.Quote:
Originally Posted by Stuperman
My cpu score > anything currently on 06
fx60 @ 3.45ghz < 955XE @ 4.9Ghz :shrug:
Working on vc scores
Originally Posted by afireinside
how can you do this???
You can jump start a PSU by wiring the green start wire on the 24 pin to a black ground on the 24 pin and flicking the PSU power switch to on will power it up. I hot glued the wire in to make sure it doesn't fall out. Hook the second PSU to your gfx and fans then power it on before powering your system on. It can kill cards like x800s that don't manage their own power though.
Nice indeed! We could be looking at Intel on the top spot :)Quote:
BTW it seems the dual dual core Opterons have taken down your "WR" ;)
Ghz diable AI for nature test ;)
What wr was passed? too many to keep track lately.
Actually I already tried that, it was a little better but not much. You ran LOD +3 right?Quote:
+5 no AI
I go into ATT and make sure all settings are set for performance under 3D settings and I make sure AI is turned off.
I open Winclk and crank up the fans and adjust the 3Dspeed of the master card.
I will test nature and see if I break 600fps at start. if it is sub 600 I will open CCC to tell it to accept new settings. I rerun Nature it will be 600+
Hey Fugger, nice job with the Intel.
As a life long intel user, its nice to seem them getting some respect in the fast world of AMD, FXs and 64 bitting.
Congrads on it!
Well, your highest CPU Score would have to have been a WR before the SMP Opterons came rolling in :)Quote:
CPU score where? the one at 4.9Ghz posted?
I'll second that, very nice to see indeed...can't wait to see i975 and the 9xx chips come of age, and conroe...so much going on, exciting times for Intel. Definitely got me wanting to switch back next time I can build a system.Quote:
Originally Posted by snipper_cr
Fugger, ROCK ON! Tho not much of Intel's fan (mainly boz of whole system upgrade with new every CPU), your results are simply superb. Hope that new PSU helps clocks a lot.
Come on Charles, we wanto see more CPU & 3D benchs with the dual core 955XE at more than 6 Ghz:D
Just to tease you, here is a very old screen from our good old days of P4's 478 and Abit's IT7 ;)
http://pedrorocha.planetaclix.pt/7top_ORB_PCMark.jpg
This is the PCMark Top10 almost 4 years ago:D , good old days ..some familiar faces already there..:)
I hope this incite you to get even more impressive results with the 955XE ..go for it my friend :toast:
good to see more and more old school overclockers setting records again.
this is awesome...I like your OCing everytime you post it :slobber:
congratulations and I smell a lot of world records for you :worship:
Have you tried any more on the P5WD2-E? I have the 955XE @ 6.2GHZ for 3DMark06 - but have to run really low FSB ( below ~ 280) or I lock up :confused: I think it's the 975X chipset - seems i ran into similar problem with the gigabyte board.Quote:
Sounds eerily similar to a cold-bugged AMD...in its case its the mem controller...here the equivalent would indeed be the chipset. Sounds reasonable to me.
yeah - scratching my head to figure that one out...but CPU score comparo to Kingpin's FX60 looks great with only 255FSB and stock X1900XTs :DQuote:
Originally Posted by Gautam
http://img33.imageshack.us/img33/418...compare6tk.jpg
Sick CPU score
Thats a crossfire score?
