Yep, and as soon as i can disable the ACPI multiprocessor crap and get temps down a little more, and give it 1.55 volts, i am gonna try for 3.4.
My dothan rig:
Pentium M 770 @ 2424mhz( just up and testing)
Asus P4P800 SE
# of cpu's:1
Measured floating point speed 3027.37 million ops/sec
Measured integer speed 9631.05 million ops/sec
Heh, re-ran benchmark and got:
2/15/2006 3:43:17 PM|| Number of CPUs: 1
2/15/2006 3:43:17 PM|| 3335 double precision MIPS (Whetstone) per CPU
2/15/2006 3:43:17 PM|| 10182 integer MIPS (Dhrystone) per CPU
I borrowed the bonic folder from the lappy and ended up with this:
2640/8499
Sempy 3100+ @2.4ghz
Thats not optimized thou.. i'll get on it here soon.
Sempron 2800+ @ 2265mhz, ram @ 190 2 2 2 5 7 16
Measured floating point speed 3148.19 million ops/sec
Measured integer speed 9559.28 million ops/sec
Dang.. these sempy's rock!
3248 double precision MIPS (Whetstone) per CPU
9989 integer MIPS (Dhrystone) per CPU
Sempron 3100+ S754 @ 2376mhz, 264x9, Mem @ 169mhz (dang PC-2700) 2-3-3-6-8-16
i love how my newcastle clocked higher than that with memory running 1:1 (though lower overall HTT) gets destroyed by that.
2434 double precision MIPS (Whetstone) per CPU
4490 integer MIPS (Dhrystone) per CPU
newcastle 3200+ S754 @ 2640, 240x11, Mem @ 240 2.5-3-3-10-2T
something seriously weird about that.
My opty 165....3730 MIPS whetstone 11413 MIPS Drystone
I'm running 1T as well. Are you running the optimized client? Lots of stuff running in the background?Quote:
Originally Posted by Bloody_Sorcerer
When you gonna clock that beast up? ;)Quote:
Originally Posted by WesM63
http://boinc.bakerlab.org/rosetta/sh...?hostid=142214
When i get some better ram and cooling. Its using the stock heatsink and some kingston value pc-2700.Quote:
Originally Posted by shmaa
Is ur 2800+ 13nm or .9nm? The 3100+ is an older paris core.
Ahh, I see... it is a 90nm sempron 64.Quote:
I have a little update here:
Sempron 2800+@2500Mhz now, but ram only at 156 2 2 2 5 7 16 1t. have to use a single 256Mb stick,because this board is very :banana::banana::banana::banana::banana:y and doesnt like more than one stick and it doesnt like most of the rams I have here. So hopefully it will like the one I orderd more than the current ones :/
Measured floating point speed 3334.16 million ops/sec
Measured integer speed 9981.71 million ops/sec
2x DC Opteron 285 (4 cores) w/NUMA enabled (~11K MB/sec)
3594 double precision MIPS (Whetstone) per CPU
4242 integer MIPS (Dhrystone) per CPU
Totals:
14276 Whetstones
16968 Dhrystones
-FCG
Originally Posted by freecableguy
probably need the optimized clients, dhrystones are low
Holy crap, I just "optimized"Quote:
3605 double precision MIPS (Whetstone) per CPU
10979 integer MIPS (Dhrystone) per CPU
Totals:
14420 Whetstones (~1% gain/no gain)
43916 Dhrystones (259% gain)
WOW!
It seems AMD definetly own The rosetta benchmark.
I've always been an Intel fan but am looking to add another machine and it looks like Intel would be a mistake!
Any suggestions for a budget priced AMD processor/mobo combination?
Would be overclocked as high as poss.
Looking for something specifically for Rosetta so max bench only no other considerations.
PS. would be my first AMD rig so be kind!
There is 1 intel that is good at rosetta: Dothan.
As far as your first amd rig goes, if you have the money, a dual core opty rig would be the best. As far as budget, sempron rigs are very good at Rosetta.
I've been browsing the user hosts of various members of XtremeSystems and have seen that X2 3800+ is doing very good - the 3800+ is a good budget DC which will be a good cruncher and in many cases also a good overclocker, because it's cache isn't particularily big.
That's a great DC CPU for a budget system.
Then we also have the Opteron 165 and 170 which is also doing good in rosetta. Actually, most AMD processors are good in rosetta (excuse me) - but as I mentioned, the X2 3800+ coupled with some cheap motherboard with onboard video would be my choice for a budget combination !
-k0nsl
Originally Posted by PFOUR
holy crap optimized client makes a difference!
before:
~2500 whet
~4250 dhry
after:
3461 whet
10625 dhry
wow!
and on a P4 2.4:
1896 whet
3134 dhry
Another update on my side:
Sempron 2800+ @ 2.8ghz 512mb Ram @ 175 2.5 3 3 8
Ram not tweaked yet:
Whetstone: 3880
Dhrystone: 11798
Stock speed Mac Mini with 2.16 Core Duo.
http://www.xtremesystems.org/forums/...1&d=1141796680
omg, even faster than a dc amd :DQuote:
Originally Posted by FUGGER
170 in sig
Measured floating point speed 4223.45 million ops/sec
Measured integer speed 12757.22 million ops/sec
gonna 24/7 here, i mean it this time! Sorry i never got around to running the 148, too much overclocking recently, but i'm back...
Opty 146 10x310
Measured floating point speed 4244.95 million ops/sec
Measured integer speed 12967.58 million ops/sec
http://boinc.bakerlab.org/rosetta/sh...?hostid=142204
Sadly this CPU is no longer with us :(
