2.6GHz will definitely challenge Intel's architecture efficiency against AMD. AMD might have theirs at 2.8GHz by then.
4 issue wide core vs 3 though, should counter the imc nicely.
That, and the ridiculous amount of L2 cache.
2.67GHZ/1066FSB/4MB @ 530US doesn't sound too bad though.
Also with the 3GHZ/1333FSB/4MB available on the server side for 850US, we could easily have an EE for 999US of this same chip but on the desktop.
It would be interesting to see what AMD Athlon FX Dual Core is like by then 2.8GHZ with DDR2, how competitive to say for certain however is hard to say.
News - Conroe, Woodcrest, Merom
Maybe these are some interessting infos...
http://pics.computerbase.de/news/13053/1.gif
http://pics.computerbase.de/news/13053/2.gif
//Edit
http://img15.imagevenue.com/loc4/th_038db_Unbenannt.JPG
http://img145.imagevenue.com/loc113/...Unbenannt2.JPG
http://img144.imagevenue.com/loc31/t...Unbenannt3.JPG
Source computerbase.de (GER)
Wow...the revolution cometh...
Perkam
Looks like E6600 gonna be very popular among Intel users. Hopefully those will be [/]mostly[/i] high OCable.
Also Very good prices
$1300??? They can forget that.
Where did you saw that price ?
E6600 only 315$
if you look on the left of the roadmaps they give estimated full system prices not cpu prices.
shame there is no socket / chipset information that would be usefull.
Originally Posted by Cybercat
WoD > Welcome to XS! :toast:
I see no Woodcrest info though?
Will there be no extra incentive except clockspeed to go EE?
Since E6600 will be fairly cheap and lowest bin, it shouldn't OC the most, but maybe good enough?Quote:
Originally Posted by Cooper
So, on a side note, if you assemble a $1500 system, Intel thinks at least $900 should go into the Intel CPU... RIGHT.
Oh sorry, I forgot Woodcrest... i'm gonna fix it... ^^
oh, didn't see that.Quote:
Originally Posted by leejsmith
I mean it`s gonna be like 2.4C Northy ;)Quote:
Those numbers look more in line of what Ive heard. Frankly I still think 2.66 is high for Conroe, most of what I know tells me that it will cap off at 2.33 not 66
From VR-ZoneQuote:
Originally Posted by vrzone.com
Hope that comes soon
:slobber:Quote:
As for EE, it should be ~3 Ghz (since highest clocked Woodcrest is 3 Ghz). Which should go up against 2.8 Ghz FX-62. Intel may have a winner there, we shall see.
I'm thinking that XE would be 3.33. Correct me if I'm wrong, but it seems that Intel always releases the desktop higher clocked chips before the server chips. I say we'll see 2.66 and 3.33 at launch and upto 3.0GHz on the server side, then a couple months later we will get the 2.93GHz desktop and a 3.33GHz server.
Thats what seems logical to me.
i guess intel will have successfully made transition to pentium netburst to M tech with conroe.. Still can play "More MHZ the better" game.
edit: Also...Since the core seems to vary from quite low clock speeds to high (EE). What do we reckon the max OC is gonna be on these things? will it go beyond 5 ghz? I apologise if i'm a little behind :/
If you think of the lower clocked chips as being like the low voltage xeons that were clocked at half the speed of the normal chips, intel categorising the chips into different market segments isn't a new phenomena. However when you consider the chips design it will not clock anything like a netburst chip does under extreme cooling. The extreme cooling helps the long netburst pipeline achieve its potential, wheras conroe eliminates the problems of leakage and as such their should be much less wasted potential.
I'm having visions of 4.2Ghz+ Conroe under phase change :slobber:
you will need very good board for to go over 400 mhz fsb :slobber:
Thats not gonna happen. Word on the street was that intel was petrified about how badly Conroe and Yonah was scaling, almost to the point that they thought of canning it and moving to plan C.Quote:
Originally Posted by vapb400
This timeline is easily followable and you can see where I am getting these facts from. The inital samples wouldnt do over 2ghz hence the 1.8 samples. The newer batches just as Presler was about to be released were doing rougly over 2.6 and now its sitting just below 3ghz. 3.3XE is simply not going to happen at all unless Intel can pull a major rabbit out of the hat.
From what I hear now the problem is semi-fixed but it will take atleast .45nm before we will start seeing over 3 on air. They are still suffering the same leakage issues since they still using "dumb" silicon compared to what AMD is using currentally
Hope Conroe XE will have unlock multi...Quote:
Originally Posted by d@rkn1ko
Hmm didn't realize that. The easy clocking of Yonah to 2.7+ in a crappy (?) motherboard with a crappy heatsink is a positive though.Quote:
Originally Posted by Sentential
We are still looking at a Q3/Julyish release?
