975X should be better and if not, there is something wrong :P
Isn't the 975 basically just a "tweaked" 955? I don't know how much better it can really be, but that may not stop me from getting one anyway if it supports Conroe :)
Much more than just a tweaked 955. If Intel is putting off i965 until Conroe Launches, then Conroe sure as hell will be supported by i975.Quote:
Originally Posted by boostedevo
Donnie27
5.1G Cinebench2003
http://andreyang.myweb.hinet.net/P5WDG2/Cinebench.JPG
Yay!! I must've missed it...what kind of cooling??
Tower 120
OMG! 6GHz+ on phase maybe? That is SO nice...congrats on the clock!
One question..
The Presler supports multiplier from x12 - x60, any mobo's with that kind of support? or just close?
Thats for the ES versions, regular retail versions will have appropriate mulitplyer for cpu clock speed. example 920 = 14 x 200mhz (2.8ghz) Its highly likely multiplyers will be locked. If they all had unlocked multiplyers it would be an Overclockers Dream ! :DQuote:
Originally Posted by Overbuary
However thats not to say that higher end chips will have multiplyers locked on certain vendors mobos. A situation like this occured with older 5xx and 6xx high end chips on certain Asus mobos whereby "cpu lock free" feature can be turned on in bios, but only to 14 x
a unique situation also occured on Asus P5WD2 mobo (955x chipset) where you can "force" the 14 x multi by setting EIST to "minimum speed" on lower range chips such as my 630. :)
I believe the XE will have unlocked multis
yeahQuote:
Originally Posted by mikeguava
retail 955xe will have fully unlocked mp:fact:
One question - all my Asus P5xxx mobo's
switched power off (like pc is simply turning off) for ~3 sec. before restart. :(
What about 975X Asus?
That's a good question. I'd like to know that also.Quote:
Originally Posted by maratus
Do you have a link for that ?Quote:
Originally Posted by Victorshen
lolQuote:
Originally Posted by IluvIntel
you dont need a link to prove that
the 840ee is already mp unlocked
plus
according to past experience, es cpu's highest mp= its default ratio
and in cpuz you gonna see (ie. 670ES 14-19)
in 840ee and 955ee, you will see 14-60
thats the difference
that with the 3 secs restart is a bug that has been from the biggining. as soon as you oc over 240 fsb ,this will happen. all the p5wd2 boards do it, something youll have to live with .;)Quote:
Originally Posted by JoeBar
vanovich :(
So, VictorWang :D :
What about your Intel mobo?
No cpu FSB OC'ing at all? (only multip. with 955 ??)
Vcore/Mem.volt. only auto?
And why did you say this one support Conroe? (1333mhz + 930 :rolleyes:)
:toast:
So you have owned an EE before?Quote:
I can't justify the financial outlay for EE cpu here in Oz, roughly around A$1,500 for each one, that kind of money could get you a Vapochill and lower end cpu..lol!:)
played with some b4Quote:
but not owning any:D
im thinkg of grabbing a 955xe but no final decisions yet:rolleyes:
Waiting for this board to go retail ;)
3dmark 05??
EE = Extremely Expensive ! :eek:Quote:
:DQuote:
yeah
thats the only reason that hold me back
:slapass:
Something I dont understand, on Asus board p5xxx, when you do a restart, it turns off the system for 3 seconds then back on.
EE = Extraordinarily imprEssive :)Quote:
I like those benchies... makes me want to shell out for EE and 975 too :)
-A.
