Originally Posted by nikhsub1
Guys, you need to understand that the AMD IHS 'numbs' the cooling affect of almost all blocks. This is the reason why in Lee's CPU test all 3 blocks are nearly identical (he did read diode of CPU for this test IIRC AND the probe on the IHS). What does this mean to you? Well, If you run with an IHS, anything from a Spiral to a Storm will yeild you similar results as far as temp monitoring goes. Say what then? A Spiral as good as a Storm? Well, for all of you that argue the only valid testing is WITH an IHS, then your answer is YES. Go get a Maze 3 or 4, it will perform just the same as an Apogee or a Storm.
