Yeah I solved the problem by turning off the voice, but am only using 1002.001 now. I didn't get a copy of the non-deluxe for who is looking for it.
1001C Bios is all you need.
http://service.futuremark.com/compare?2k1=5734604
Yes, every bios version shows a post error of 25. It's a notice failure, not a stop failure. It seems the betas don't have Betty turned off the way the final releases are.Quote:
Originally posted by linkponder
from what i have read, and don't quote me on this, is that the error has existed all along, but only now, with the 1002.xxx bioses, is it that the voice output has been activated. again, not sure, just what i read. either way, i ignore the message because i know me mem is fine.
what betty doesn't work :(
I never tried her but that is a bummer :(
LOL
terramir
Hi, here is one at 210, stock board. It's only prime95 and 3dmark friendly though, games no like.Quote:
Originally posted by Mikee
Yeah that's typical though mrbucket. Also why I wanted to see linkponders PUBLISHED 3dMark result (which I don't expect to see).
http://service.futuremark.com/compare?2k1=5572599
OK, fair enough...and good to see. What is your setup, in particular anything unusual like volt modding, water cooling, etc. Did you OC your Radeon at all? Thanks for the info.
Nothing other than bios settings, I actually run my fans slower than usual to make the machine quiet. Too bad QFan doesn't work, I am using those zalman resister jobs and they get quite hot.
Basica case, 2 12cm fans, one at front and back, going at 2000rpms or thereabouts, regular thermalright ax7 with 80mm fan at 2000rpms. No volt mods.
I generally overclock the card to 378/344 for benchmarking 3dmark, I tend to leave it at stock otherwise.
My highest score is 17K at 200Mhz fsb, do a search on my email address there. 16.9 / 17K seems about where my system is at without going to exotic methods.
2GHz, 200fsb
http://service.futuremark.com/compare?2k1=5673340
