1. Are you guys able to take the X1800 XL to X1800 XT speeds on stock volts? I see many of you going past those speeds and just wanted some clarity.
2. What software application are you using to change the voltages?
3. Can you remove the cover and slap a 80MM fan on like we did with the 7800GTX cards? Links
here. Since all the memory chips are on the front of the card, I'd imagine a nice 80MM fan blowing over the cooler would make a world of difference.
Thanks in advance... thinking about grabbing one to play with! :)
