Yeah, and not very tweaked....anyway, keep up the good work with the DI, AFI :D
Ram is only 250 @ 3500mhz and SP2004 running can't be very good for pi times... :(
Set SPI to realtime.
/me smacks self
Forgot that...
You're welcome :D
JASONNNNNNNNNN why is my base -60C under load :stick:
realtime 1m @ 3511mhz = 24.782s -63c base looks like best temp but it goes up to -59c and hangs :(
I would bet that's the aluminum showing its true colors.
Pretty good 1M time, btw. :D
screeeeeeeeeeeeeeeeeeeeeeeeeeens pls :slobber: :slobber:
Some nice screens here, I reckon.Quote:
Originally Posted by dinos22
:).Quote:
Originally Posted by Vapor
lmao...
All the ice I have left over is packed in the tube and I'm loop 5 of 32m at 3.4ghz. 3d01 @ 3.42ghz 618/604 clocks on my vmodded 12 pipe x800pro got me 38.4k and second place on the orb :D After 32m finishes/crashes I'll grab all my screenies and throw them on my USB drive so I can upload.
That looks good, glad to see you got the CPU worked out on DI... Maybe you'll find a good ram/CPU setup at some point. Pretty nice so far though :toast:Quote:
Originally Posted by afireinside
Less than 200Mhz away from a 100% OC :slobber:
