Yeah I'm very concerned with BIOS choice. I have a Connect3D Coming, can I flash it with the modded Sapphire GTO2 BIOS?
Man if I only had a PCI-X board I would order one of these! Damn AGP lol. :p:
Nicks, as far as I know, youll have to pull the heatsink and check to see if you got a R480 core or not, If so, I believe the mod process is the same. The thing with the Saphire is it is just a guarenteed r480 core.
no even with r480 cores some cards cant be unlocked, the only GTO non GTO2 that i heard of that can unlock is the Connect3D
Originally Posted by LexDiamonds
MM, nope. :) Check this out!
Original Link: http://www.techpowerup.com/articles/...ng/vidcard/127Quote:
Originally Posted by techpowerup![/quote
Hopefully i'll have some results soon. I'm working with afireinside right now to see if i can get my cpu to overclock. (never played with the DFI or the TCCD I have)
Even though you are from Ohio...I'll helpQuote:
Originally Posted by Ostate21
Wes, did the card at least mod with no issues?
Still working on it, the 6600gt is still in while i play with CPU. Finally got things ironed out with that.. getting ready to flash now.
x800 gto2 card run cool ? :confused:
This card rocks!!
Flashed with no issues, i did have to force the flash but it works.
ATI tool shows 16active pipelines, running 3D05 now at 520/540 :D
Best $235 i've ever spent!
Screens to follow....
EDIT:
Here are the screens, i'm just going to link them cause they are fairly large (1600x1200). Both ss, where done at 520/540. I'm going to try 540/590 then head to bed. More tomorrow.
http://www.needmoreboost.com/wes/x800stockcpu.jpg
http://www.needmoreboost.com/wes/x800023cpu.jpg
comparing to my experience youll hit 540/590 no problem, my if i clock up to 570 core though my system hangs so lets see what you get :D
i idle 34c and 55c under load with some ac5 on itQuote:
hehe.. this is fun :)
Last one for tonight:
http://www.needmoreboost.com/wes/x800pe23.jpg
I tried 600/600 and did a 3D01 nature run, it was about to finish then crashed with a vpu recover. So i'm sure it'll do somewhere between 540-600 ;)
Eince,
Similar temps here.
600/600 is what I am going to shoot for with my gto2. :stick: Using the stock cooling or something else Wes?
around 40deg.C idle, and about 60deg. C full load (rm temp: 28deg.C, naked case), all are stock :DQuote:
Originally Posted by Supertim0r
I feel some warm air spreads out :fact:
Yes, stock cooling for now.Quote:
i got JUST under 7k in 3dmark with 564/600 with the x800 mem timings in this forum. i envy those who can go up to and past 570, could it be that i have a bad clocker?
*edit* noticed i put the wrong core speed haha
Awe, NT einCe. My goal is at least 4500 in 2005 :D.
Hey don't dog Ohio lol! Any ways I thought that only the PCI-X ones are the only ones that can be unlocked. Or am I wrong? :confused:Quote:
Originally Posted by jumanji969
I might get it tomorrow or friday...wes63: can you tell me exactly how did you flashed it.....in PM please ;)
Tedy,
YGPM.
I'm going to start playing more here soon ;) I want 7k 3d05
what drivers are you using? ati catalyst 5.9? is this the control panel version or control centre one? also, is ati tool a seperate program? just installed mine, and need to download drivers.
KITT,
I do not really know what drivers, whatever came on the sapphire disc (i'm on dial up). ATI tool is a seperate program that you can get here :
http://downloads.guru3d.com/download.php?det=725
Good Luck.
Default clock is 400/980 right ?
and for X850XT is 500/540 ?
Mine has unlocked sucessfully, and is so far happy at 575/600 :)
Get 6555 3dmarks in 3d mark 2005 :D
I'm not finished yet, this thing has more in it.
*Heads off to OC some more :D*
