ozzimark,Quote:
Originally Posted by ozzimark
Good to see you got the CPU under water now,
Would I be correct in saying tht you arnt entirely happy with the clock speeds your chip is clocking to? You mention tht 1.55v applied to the CPU with water gives you arnd 2.8ghz stable and tht the chip is NOT scaling any higher with volts.
Your temps are very good while idling, but wht are they like under load? If you are seeing increase of over 20C under load (i.e. temps above 50C) then you definatley (if there is such a thing!!) have bad contact with the core and IHS.
I feel tht without taking the shim off you will never really know if this is the case, curiosity always gets the better of me, time will tell with yourself.
Something which is concerning me is the information coming out tht brainpower pcb's wont work with these CPU's.
:confused:
I really hope this can be verified in the next few days, I personally dont have any other ram apart from tccd and cannot commit myself to purchasing a Opty 939 unless I know tht the CPU will work with the Ram I have. I hope to see some verification from peeps who eventually get hold of the CPU to see if this information is indeed true.
