YESQuote:
Originally posted by Volcom
Yeb
So u recon this is a good steping right ?
YESQuote:
Yeb
CPU: Athlon XP 1700+
Stepping: JIUHB
Cooling: SunCore CopperStorm
Voltage: stock
Motherboard: Epox 8RDA+
System Memory: Kingston DDR400
Overclock: 2145MHz (46% or 679MHz)
terramir:
actualy dude i think your right cause today i was feeling lucky and went for the 2400 mhz to test it and discovered that i can boot into windows and surf and chat and use windows just fine infact temps are great i do have to use 1.75 volts but hey thats still not bad one thing i did notice i thought was wierd was that anything over 1.8v it wont boot? ive read about this but didnt think anything about it until i got mine and gave it try.. anyway back to my story i had it in 2400 mhz mode for a couple of hours and decided to try 3dmark and as soon as it ran the first car case test it went into the second and bamm right back into window!! now i tried relaxing the memory and alot of differnt things with no lick thats how i found out about the 1.8v and above being a no go.. well i suspect this is a memory issue maybe even a psu ise as well so until i get a better psu and a stick of memory im going to just have to be happy with 2300 mhz wich isnt bad cause my xp2600 well only do 2400 mhz and i suspect it may do more when i fix the psu and memory problems atleast i hope so i was hopeing to get 2400 plus out of the xp1700 and atleast 26/2800 out of the xp2600 so like i say i might just be asking for too much but i still think this xp1700 has alot left in it? i mean temps are low voltage is low cpu runs great.... oh well ill just have to keep up the tinkering and try and figure it out cause im not ready to call it quits yet!
later guys perc.
CPU: Athlon XP 2100+
Stepping: AIUHB
Cooling: AX-7 with smartfan2
Voltage: 1.6
System Memory: Kingston hyperx3500
Overclock: 2517mhz(stable for a half hour) posted at 2610(about a 50% OC)
1I wish I had that one
can you post your
label ergo the atepping and stuff and where the heck you got it :p
terramir
2300Mhz @ 1.7 Vcore, was stepping in 0.05v instead of 0.025v.
http://security.cclcomputers.co.uk/acatalog/cpu_amd.htm
Bought it after hearing that the place sold this stepping.
http://www.doomiii.pwp.blueyonder.co.uk/xp1800+.jpg
http://www.doomiii.pwp.blueyonder.co.uk/2_075v.jpg
This took 2.075v. Tested playing UT2K3 botmatch, watertemp idle 22'c / CPU idle 32'c / CPU botmatch 36'C.
Haven't tried 3dmark just yet, to see if I can beat my old score with 2400Mhz xp2400+, I doubt it since the ambient temps have risen therefore the 9700pro won't climb as high.
I still have 0.125v more vCore to play with so this may not be the absolute ceiling. Its still a very round number. 2.5Ghz!:banana: 63% overclock.
Really nice overclock! So the drama continues! Looks like the JIUHB madness isn't over yet, and in fact DLT3C seems to be the magic voltage. The date is interesting 0312SPMW. Somebody criticized me because I beleived two people juxtiposed their codes,and had questioned it. Low and behold it's SPMW, not SMPW.
EDIT: Never mind, by bad sorry. There's all sorts of different codes.
saaya, I just ordered a JIUHB 1700DUT3C 0307. Do you think I should keep this or for a $1 more have hem change it to JIUHB 1700DLT3C 0302? I haven't been able to find many posted results for week 0302? Mabye you've read something about either of these? I have untill Monday morning to change order.Quote:
Originally posted by saaya
1700+ axda 1700dut3c jiuhb 0308 (relabeled xp2600+)
2050@1.6 36°C
2133@1.7 39°C
2200@1.8 40°C
2260@1.9 46°C
2322@1.9 47.5°C
2322@2.0 51°C
2385@2.0 51°C
havent tried any further so far... aiming for 10x250
CPU: XP 1700+
Stepping: JIUHB DLT3C (0313RPMW)
Cooling: Alpha PAL8045 & Papst NGML
Voltage: 1.75V
Motherboard: Abit KX7R
System Memory: Corsair XMS3200 256MB
Overclock: 2400MHz (12*200)
soon and i'll have my h2o ;)
is a 1.7 DLT3C ok? or do you want to see only 2.4 to 2.8 scores?
if it's ok then here I go:
XP1700 DLT3C JIUHB MPMW 0309
Air cooling SK6 + 4500rpm 70x70 fan
Voltage: 1.85v
MB: NF7-S 2.0
Mem: Kingston (Winbond BH5) 5-2-2-2
Max Rock Solid OC: 2400 mhz (200 x 12)
Regards,
Apocalipsis.
Welcome to the Xtreme Apocalipsis, really nice overclock! Your at 2400MHz with 1.85V, depending on your cooling, that chip could really soar.
EDIT: what am I saying, your already over 900MHz, you are soaring.
Here's my little baby at only 1.75Vcore, 29C and on my Soltek SL-75FRN2-L with C1 stepping, and VDD adjust to 1.8V (currently at deafult 1.6V) 13x185FSB.
Could you post the entire sticker code of the chip? Please :)Quote:
Stepping: AIUHB
Voltage: 1.6
Thought I'd add my system right now, have ordered new cooling and RAM, will add the upgraded system later on:
XP 1700+ (AXDA1700DUT3C, JIUHB0302WPMW)
2*TwinMOS PC3200 Cas2.5 256mb (non-winbond, sucks)
ASUS A7N8X Deluxe rev1.04 bios 1004
Volcano7 (not +version, sucks) & AS3
running @ 175*2 (crappy FSB) - 2104Mhz
I used to run it @ 12.5*175 but I can't get the Volcano to stay completely flat on the CPU-die, thus giving me errors in Prime95 fast.
New components ordered:
Alpha 8045 block + pabst 80mm-fan, trying low-noise solution first, if not satisfactory going for a 50CFM-minimum pushing fan.
Corsair TWINX512 CMX3200LL - 2*256Mb matched pair
That SHOULD give me a little more room to play around in. If not, I'll change the mobo for the Abit NF-7 2.0 or something like that.
my 1700+ on a Abit NF7 1.2:
http://downhill666.bei.t-online.de/2606MHz/2.8GHz.gif
Skynet would you be willing to post your entire sticker's code, I'm still compiling data about the overclockability of TBred. Thank you.
1700+ JIUHB DLT3C 0308 SPMW xxxxxx25xxxxxxx
AXDA2100DUT3C
9597107260347
AIUHB0248MPMW
2100 T-Bred
Epox 8K5A2+
512 Meg XMS PC3200C2
Maxtor 6E040L0 ATA 133
Radeon 9700 Pro
Enermax 350 Watt PSU
198x13 = 2572 Mhz @ 1.90V
Water Cooled
Computer Specs & Bench Marks
__________________________________________________
My Back Up Computer
AXDA2100DUT3C
9769907260091
AIUHB0301MPMW
2100 T-Bred
Epox 8RDA+ A3 NB
512 Meg Geil PC3500 Ultra 4.5ns
Radeon 9700 Pro
Antec 430 Watt PSU
222x11 = 2441 Mhz @ 1.90V
ThermalRight SLK 800A with 80m Vantec Tornado
hey SKYNET 2800mhz, I can only say WoW.
Really nice overclock there.
Thnak for posting those codea and congrats!!! :)
mine seems to be getting better with age i can run 2.5+ now @ 1.85vcore but thats at 194 fsb the ati no like and to lazy to change multi again hehe so im a 2.444 1.8vcore 13x188.
To all the DUT3C owner, did you burn you chip in? Cause my chip won't go over 2.3GHz@2V i can boot into windows at 2.4 but it crashes even with 2.2V. I can boot @2.5GHz but i can't load windows
Switching to watercooling, now the same chip overclocks to 2510mhz at 1.95v totally rock solid.
CPU: 1700
Stepping: DLT3C Week 0319
Cooling: SLK 800 / Vantec
Voltage: Vdd = 1.92, Vcore = 1.850, Vdimm = 2.90
Motherboard: Epox 8RDA+, Rev 1.1, A3
System Memory: 2 x 256 HyperX PC 3500 @ 7-2-2, Cas 2.0
Overclock: 12.0 x 210 fsb = 2520Mhz ROCK SOLID
Skynet thats amazing!!! you HAVE to get a prom or lend it to a friend with a prommie to see what it can do with phase change!
that could be a 3.2ghz+ stable chip !!!
