Originally Posted by gclg2000
Hey bud, awesome work!!
But i have a couples questions(concerns) about your design.
I dunno about doing the dual expansion valve thing on the 1st stage. I think one would be better for load balancing. I'm not the expert, but what happens when you have a large load variance on the twn HX's. Let's say you shut one of the stages off and now the heat from the 2nd HX is no longer around. The expansion valve that has no load on it now, should squeeze down as the temperatue drops and it's sensing bulb dropping the temp and causing a variance in pressure difference on the high side and could affect the other metering valve's function.
I think it might be easier and more effecient to just use one expansion valve for the 1st stage...let the 1st stage evap coil over both HX's, and then one sense bulb can adjust the capacity of the system without interferance from the other stage shutting off, or having a smaller video card load.
I just think that it may be more effecient on the 1st stage to have one expansion valve. I think the 2 valves in parallel would mess up each other's capacity functions.
If you were to do the dual expansion valve idea, i think it would prob be better to use a Constant Pressue expansion vavle instead. That way once you get the temp's were you want them with everything going, at the set pressure you assign it, the stage would be able to handle at least some ideal load @ a certain PSI or anyload less than that (even if there is no real load).
I've used a Parker CPEV (AA-A7 i think it was) on the 2nd stage of my 2nd cascade and it boom, all done for.
These are just a couple things that i've though off. And if your gonna run part #23 (the suction line HX) it would prob be best to have the sense(ing) bulbs after that HX so they can account for the load that add's too.
But by far, this is the coolest case/frame for any cascade i've ever seen.
I bow down to you for that!!
Awesome stuff
