uhh isnt that what the fx series is for? basically for Xtreme overclockers? :stick:Quote:
no, no chip is designed to OC. And besides, if you read what oppainter had to say, at normal temps, his memory controller was just fine.
Well yes and no if AMD had to live with sales from just people with -90c cascades then they would go belly up . Don't get me wrong i'd love to see Opp
hitting high htt and mhz at the same time , I just don't think AMD has too much to answer for . :p: Just my opinion tho so salty grains and all that
Originally Posted by Rezag1000
Actually AMD is promoting the new FX57 as "the chip to overclock"
BTW what is the actual voltage - the one I calculate myself or the one shown in bios monitor?Quote:
Originally Posted by stealth17
For example, if I set
1.35 + 1.35*0.26 = 1.35 + 0.351 = 1.701
But it shows 1.64 or 1.66 in bios. So, which is the real one?
Same with DRAM. If I set 2.7, it always shows ~2.73
go by the one in the bios reading.
Originally Posted by xgman
You guys cant fault AMD because the memory controller doesnt like -90 deg c, geez, yes it's for overclockers but how many "every day" overclockers are cooling their CPUs to -90 deg c. I really doubt even the FX57 was intended to be cooled at temps that low. Cut AMD some slack on that one, how would you function in a tshirt and shorts at -90 deg c below?? LOL
100% agree with you dnottis
just because a CPU does not like -90 degree operating temps has nothing to do with a CPU being "bad" :rolleyes:
If the .01% of ppl using PC dont like this then tuff titties :fact:
http://img185.imageshack.us/img185/2097/28sec5pw.th.jpg
i love the 704-3 Bios with my 3000+ Venice & 2x512mb TwinmosTwisterPro 3200 TCCD :woot:
Much better than previous Versions for my System.
Great Job Oskar Wu :clap:
i can see what you are saying but how man "everyday" overclockers buy a $1,200 chip to get a few hundred extra mhz when a plain a64 will do the same with "everyday" cooling?Quote:
Originally Posted by dnottis
:stick:
Kiwi-
my measurements were all with a digital multimeter, i never go by the sensor reading nor should you :toast:
Where is the vcore measuring point on NF4? Could you link to the picture?
http://www.xtremesystems.org/forums/...818#post927818Quote:
Originally Posted by kiwi
When measured with a dmm its pretty close to what it supposed to be using the vid+vid special..
what is the cpu vcore or the vdimm?Quote:
Originally Posted by THunDA
the vdimm i dont think i have seen a board yet that doesnt overvolt the vdimm by atleast .1v
have you tried enabling the usb mouse / keyboard in the bios? it defaults to disableQuote:
Originally Posted by smids
ok this bios rocks my gskill tccd went from 300-303ish benchable at 2.5-3-3-6 to 310 rock stable and 315 benchable!! thats right ddr630 2.5-3-3-6 @ 2.8 volts all tight timings
now the bad side is while testing this out and achieving this wicked mem clock i got blue screen?? was like wtf now one mem module is broken and will get errors at any speed any setting but the other module is perfect and will still do ddr630 2.5-3-3-6 so im not sure if it was the bios or just my mems time to die but ... its dead lol
________
Chloui
oh,it's nothing with me !! :D :DQuote:
Originally Posted by Pandur
Well once OPP gets hand on few more FX57, we might have some idea. Some FX-55s had problem going extreme temp back than as well.
A comparison between 704-2 and 704-3 for my Winchester + TCCD.
Settings for 100% stability (prime, spi 32M, memtest, S&M memory test, games, 3D MArk etc...)
http://img301.imageshack.us/img301/9...bios7040bf.jpg
704-2 rocks :woot:
PS: dram bank interleave: enable
Flashed to 704-3, and it fixed my coldboot issues with 5v jumper right off the bat. I was using 623 bios before. DFI rocks!
704-2 is working well for me. 1 x 32M and 2 x 16M Pi tested and no problems so far
http://homepage.ntlworld.com/najmudd..._1.53vCore.jpg
-2 bios works really well with TCCD based memory. I support XiN's results.
Just tried 704-3 and seems my vdimm is overvolted
bios set 2.5v = 2.63v and 2.6v = 2.72v ??
Originally Posted by eva2000
http://www.xtremesystems.org/forums/...742#post946742Quote:
Originally Posted by bigtoe
ah i see thanks Enz0 :)
