Originally Posted by bigtoe
Gotta luv you guys...
always 1 step either behind or just there.
Duonger
Duonger
Jeez duonger maybe I am taking that wrong but seems like a cheap shot against OCZ. Not very good form.
Cheap shot? Naw, just healthy competition.... :banana:Quote:
Originally Posted by chunkylover77
I think they know eachother, but I could be wrong. Maybe Tony owes Dounger a spank ;).
You should let your products speak for you. A representative for a company is that companies voice. He should act like it at all times. I am not picking on Duonger either as I would have said that to any companies mouthpiece. Just let the products speak for themselves. I mean the redline really speaks for itself.
Edit: Also sorry Duonger if I did take it the wrong way.
Edit2: From Duonger's comments can we take that to mean that this memory is Mushkin? I am seriously interested in this stuff. Have been looking for good 2 gig kits for a very long time now.
It's good that companies are developing decent 2GB kits of RAM. 1GB is starting to be not enough...
its cheaper to get a 2x1gb set and run lax timings with 1t then expensive redline and you need two dual channel sets of that and performance between the two is real closeQuote:
Originally Posted by charlie
for instance newegg has redlines for 190 so its gonna be 380 bux for 2 gigs and that will perform really close to ocz performance 2 gig cost 215 dollars kit running 3-3-3 but 1t that is if it oc that far well you see my point
________
Home Made Vaporizer
Of course it's Mushkin. Don't you remember who previewed us Redline?
hmm, that ocz sounds good. hopefully soon is like a couple of weeks or less?
Originally Posted by Dumo
how the hell can you get mixed pairs to work?i cant even get 2xpc3200vx + 2xpc4000vx to work together. also have 2xpc3200 twinmos bh-5 and 2xpc3200 mushkin blue and cant get any of these to work in combo. only 4 dimms can get working together are 4x512mb vx pc4000????????????????????????????????
Originally Posted by pumbertot
Have you tried the tweak Bigtoe mentionned of placing the best clocking memory dimm in the slots farther away from CPU,the weaker modules closer to the CPU * due to trace lenght*
This is even more of important when using 4 modules I beleive
So best bet I guess is to test every module individually and place them accordingly,just try to test them at 2T timing like the will be with 4 sticks,1T sometimes differs slightly on settings to get stable.
My Crucial Ballistix PC4000 is pretty much the same. At 2.8v it would do 3,3,3,8 @ 250MHz on my DFI UT NF3 250GB. On my DFI NF3 Ultra-D they'll do 3,4,3,8 @ 250MHz with 2.7v. Any more voltage on this NF3 Ultra D and they become unstable :(Quote:
Originally Posted by Vapor
On both boards the RAM absolutely refuses to do any lower than 3 on CAS, RAS to Cas Delay(RCD) and RAS Precharge(RP). So that guy who got 2.5,2,2,x was bloody lucky!!!! :(
Indeed he was lucky...in the past week I've come realize that while 260 3-3-3-8 is 3DMark and SPI <4M stable, not even 250 3-4-4-8 at any voltage is memtest or SPI 32M stable, so I'm RMAing, hope I get back some gems, or even ones like nugzo's.Quote:
Originally Posted by Walrusbonzo
I don't think the 3DMark01 score is a good indicator of gaming performance in this case. Someone needs to use Fraps or a similar program and compare the Minimum FPS with 2x512MB, 4x512MB, 2x1GB while playing HL2, BF2, Doom 3, etc. Because all of these RAM config's will maintain a decent FPS at most times, what really matters is which will keep the FPS the highest when there are tons of people on the screen.
Keep in mind he's using an FX. They have superior memory controllers.;)Quote:
OCZ Announces PC-4000 EL 1GB Gold Edition
Press Release - http://www.ocztechnology.com/aboutocz/press/2205/140
Product Page - http://www.ocztechnology.com/product...l_channel-2gb_
I wonder how much they'll be.
Sweet!! I'll be making a 2x1GB purchase soon so I'm anxious to see how these scale. Anyone know if these use the same chips as the Ballistix 1GB modules do?Quote:
Originally Posted by Capt_Caveman
Nothing special compared to their 4000 2.5 3 3 that will be out. Might as well just get balistix if your gonna get those. Prob gonna be a good price for mid end ram though.Quote:
wait they are going to be releaseing two lines of pc4000?? i thought the testing process didnt work out too well and they rated the 2.5-3-3 to 3-4-4Quote:
Originally Posted by fareastgq
bigtoe or any ocz rep can you comment on this????? also where can we buy these things first?????
________
I INHALE IOLITE
btw whats the msrp on these??
________
COACH PURSES
I havent seen 2x1024 tracer even running at its rated 3-4-4-8. No matter what it defaults to 3-3-3-8, even at 285+. OCZ will your new 2x1024 do that? Any chance of gettin 2.5 out of em? What IC's are the OCZ's using?
Has anyone seen the guy with 1.5-2-2 with his G.Skill and Mushkin Redline working together at 250 mhz and 3.5V?? =)
I thought the A64 didn't support CAS 1.5 ...Quote:
Originally Posted by dmo580
It's just another tight CAS setting that Oskar gives us the option of using....it's not actually CAS 1.5 (it's just called that). Many people are reporting more stability with it.
Could an OCZ representative clarify some questions about this memory..?Quote:
Originally Posted by brandinb
2GB (2x1024) D/C Kit PN - OCZ5002048ELGE-K
When will this memory be available for purchase?
What will be the suggested retail price?
Lastly, is the memory being touted in this thread with 2.5-3-3-8 timings and OCZ5002048ELGE-K the same product?
Thanks..
