from what I have read and seen on my own NF7 it looks like there is something really flacky about the multipliers. What FSB were you using and at what multipliers. I may be wrong but it looks to me that if you use the low bit multipliers then a FSB of 200+ is no problem. When you change to high bit to maximize the CPU's mhz's then you are lucky to get 188 FSB without trashing your OS.Quote:
Originally posted by twiggy
Ok I couldnt sleep ;).
Anyways the multi's are kinda whacked. Im using a 2400+ and so far i can use 15-11 multi. 10.5, 10 and 9.5 will not load into windows. However 9 will. I havent tried anything lower then 9 or higher then 15.
