Originally Posted by madpete
Hey guys, a while back I started this thread after my second lot of ram died on me (first lot was OCZ VX). Due to two different manufactures of ram, the rumours floating around, and the fact that I had stuck to the warranty voltage and provided plenty of cooling I blamed the DFI for the death of my memory.
3 or 4 weeks ago I received of replacement Redline modules from Mushkin, determined that this time the memory would not be killed by dodgy volt control I brought a OCZ DDR Booster and an OCZ PowerStream to replace my old Enermax PSU.
With these installed I set about installing the Redline, which I had set at the following:
260mhz / 1.5-2-2-6 / 3.46v (using booster). The ram handled this no problem, with no instability and no errors in any memtest I ran.
All was fine, and I was sure that I was safe this time round, until yesterday it happened again. Exactly the same thing, one stick dead, one stick ok…system wouldn’t post.
I would like to say now that given what’s happened, I no longer believe the mobo was at fault for the death of any of my ram. I now agree 100% with Pershoot’s earlier post that CH-5/UTT cannot handle high volts for periods of time, I have no experience of BH-5 yet so I can’t comment on that.
If you have to get / use CH-5/UTT I would keep it under 3.3v no matter what the cooling, and buy from OCZ or Mushkin both of which have given me excellent support when I needed it.
The point here today anyway is to set the record straight on what I say earlier in the initial post, hopefully I’ve done that.
Pete.
