Originally Posted by LOE
There is no need to explain to me speakers and sound - I'm in audio recording for half a decade. In your words sound engineers who make sound buy overrated equipment cause they are dumb? And before there are titanium diaphragms sound will most likely project directly into our hears
For someone who says they "know audio", you certainly don't have a leg to stand on:
http://www.audiovideo101.com/dictionary/diaphragm.asp
"Diaphragms must be stiff and sturdy while also being light weight. They need to be able to move and respond quickly, necessitating light weight. They also should not flex or deform as they move (which would cause distortion), requiring a strong structure. Most domes are made from some sort of light-weight metal (typically aluminum or titanium), silk or a light weight plastic. Midranges and woofers are typically cones that are made of some type of treated plastic or strong, specially formed paper. Diaphragms are what make it possible for speakers to generate sound by vibrating and exciting the surrounding air with their vibrations. "
Furthermore, that Yamaha amplifier is made up of about 75% quality and 25% simply for show.
Sure, it has a lot of features... but how many of them actually get used on a daily basis? Most of them will never be used, yet you pay for every single one of them.
I mean, come on, who needs that many Dolby Pro Logic profiles? My amp has 6 and I don't use any of them, ever. Dolby pales in comparison to DTS, and unfortunately, the only way to get a source that's encoded at 24bit/96khz is through DTS.
