X2 3800+ CHBHE 0526UPBW
Large FFT
Vapo LS
-33c Display on LCD (dunno real
temp)http://sanwork.com/huy/PI.JPG
Large FFT
Vapo LS
dualcore @ 3ghz. now that's nice.
Thank you...I'm extremely pleased :party:
Looks like your screen shot has you at -14c at idle. Fantastic screenie BTW. Where did you get your X2 3800+?Quote:
Originally Posted by buckshot
Used to get problems like that with ram, just make sure it doesnt need more voltage to memtest, however being able to prime @ large fft's wouldnt make sense...Board voltages?Quote:
Originally Posted by pduan87
Can U do it ag'n with SP2004 ? on ur screenie plzz show ur system properties and boot @ 3GHz. Don't Use Clockgen. Thx.Quote:
Anyway very nice Overclock
:toast:
I got LDT at 1.2, chipset at 1.5Quote:
Originally Posted by Vincentvega18
@ gundamit Thank you...I got my 3800 X2 from Fry's in Socal. I scored big time. Thank! O/Cing Gods :clap: :toast:
@ Zanr Zij Thank you ...........
I didn't use clockgen. This is a straight boot to windows @ 3GHZ. I'm not sure if you're implying that I might have faked my screen shot, but I will post another with SP2004 this time as requested.
I see mostly 2700-2800mhz, but one or two near 2.9 and of course that dual core with the vapo, but that's with sub zero....so
I wish I had seen this thread earlier, I ran blend last night for about 10 hours and should have just let it keep going.
So who's in the lead with a single core?
Hi guy's my 1st post here. Is there any benifit useing priority 10 over 9 in prime? My reason for the question is that I was primeing for some time without monitoring temps and found out later that temps were higher than I thought.
CBBFD(0437 I think)
XP-90 Panaflo M1a
Max temp 48C
Small FFT
This is my old 3000 winnie. It's stable up to 2.7, but takes 1.6v to get there.
going on 12 hours now @ 2908mhz :)
See you all in 12 hours, lol, (crosses fingers)
Max temp so far is 40c, but I have the daytime heat coming...
edit:
FAILED after 13 hours! Doh! Pretty sure it was memory related though...
3200+ Venice 0517BPEW @ 1.50Vcore
MSI K8N Neo2 Platinum-54G with 1.36b BIOS
2x256mb KHX3500 DS DW-50
2-5-2-2 1T DC 3.2V (Kyosen mod)
http://koti.mbnet.fi/dani69/MSI%20K8...e_42h37min.gif
PLZ if any1 knows what this is all about then share the info, myself thought it was a sign of too less voltage feeded to the cpu as it for me helps to get my sandy booting to windows. Who knows maybe I have this same prob, perhaps my sandy would be prime stable if I only could get past that point without feeding a lot more voltage to it... a bump from 1.536V to 1.62V is usually needed for any speed between 2.7GHz - 2.75GHz from 2.6GHz for me.Quote:
Dani, you can run your Venice on the 1.36b Bios? I heard it wasnt compatible with it...
Originally Posted by Dani
I solved it. It was problems with ram timings. Set your DRAM drive strength high (6-8) and see if that helps.Quote:
Originally Posted by RPGWiZaRD
These probably wont help you much but if anyone else with the 1gb Crucial Value is having the same problem, these are the settings that I use:
http://img399.imageshack.us/img399/3...5stable1rg.png
Best BIOS so far for me with Venice :)Quote:
Originally Posted by OCForums_Osirs
1800@2700 1.65V AIR - 28 hours Prime Large FFT.
Screen and system specs are here.
Back again, this time I've got my RAM to DDR600... :D
http://members.lycos.co.uk/oasked1/prime24hr.jpg
The DFI's 623-3 BIOS really helped. :)
I did once bother to do a 23h 48min Stress Prime run. It never reached 24 hours...
DO NOT TRY TO MINIMIZE "Central Brain Identifier" (Status Bar -> Minimize), ESPECIALLY WHILE RUNNING PRIME!
I don't want to see this thread die. :) 3ghz+ 1m super-pi and other less stressful benchies are nice, but it is much harder to get a high clock 24hr prime stable. After removing ihs, I have gained 50mhz. Here is 25hr+ at 2.8ghz. Large fft. Stepping in sig.
3200+ LLBLE 0515APAW
Watercooled
Temps were 42c max
I know this was blend but look at my RAM speed and voltage!
http://img.photobucket.com/albums/v475/musk/prime24.jpg
3200+ Venice 0517BPDW ZM7700CU AIR cooling :toast:
http://koti.mbnet.fi/dani69/DFI%20nF....64V%2025h.gif
Try 25/26h :confused:Quote:
Originally Posted by musk
Good idea for a thread, though prime still isn't liar proof. It makes me laugh how all the realistic (modest) overclocks come out, but in the thread that was about 24/7 overclock, everyone was like "I leave my venice at 2.9 1.6v 24/7 on air."
I would post mine, but that would cost me 24 hours of no World Of Warcraft. I did 16 hours @ 2.77 the first night I bought my venice just to help cure the AS5.
