3.73EE ES suicide shot. cooling done by the coldness of the air outside and a fan blowing it into my pc.
http://img223.imageshack.us/img223/4...p148ghz2kc.jpg
Just a 5% overclock...Intel 3.2 GHz EE to 3.36GHz through my motherboard ASUS P4P800 Deluxe i865Perl chipset...I have had it up to 3.68 GHz but had some stability problems...Jet 7 overclockers fan...water cooling would be better.
950ES at 4GHz, its in a Shuttle so not even tried higher.
Waiting to set up my 955XE ES, tested to 4.26 in the lab on air, 5GHz under the Vapo but the D955XBK was starting to reach its limits.
Got a 840XE ES kicking around too which I had up to 4.4 in the Vapo, again in the D955XBK.
Almost tempted to fire up the LGA775 3.2 Gallatin-2M system to see what it'll do.
helloQuote:
Originally Posted by proth
I have one question about Presler Extreme Edition
You don't have one ES processor but you can boot with a ratio 17 instead of 13
All Extreme processors have unlocked ratio or only the ES version
All Extreme Editions are unlocked since either the Pentium 4 3.73GHz or the Pentium Extreme Edition 840.
The Conroe based EE will also be unlocked.
P4 Extreme Edition 3.73 (ES) I seen another guy had the same CPU as mine, kinda weird, Ive only heard of a couple like that mine included.
P4 EE 3.73, P5WD2 E, Mushkin EM 4300 3-2-2-8, Ultra 600, TDX water block, dual core dual pump water system. SuperPi was realy slow due to ram, I havent went back to adjust it just yet. I realy dont want to loosen the timings but maybe aIll give it a shot and see if I can get this into the 20's. Max clock is around 4.4.
Max clock so far. Wich a higher multi was available.
http://valid.x86-secret.com/show_oc.php?id=6070
http://valid.x86-secret.com/cache/6070.png
Aircooling @ 1.8 Vcore
Pentium 965XE (ES) @ 4.4Ghz. On a Asus P5WD2 Premium 315x14=4410Ghz all on Air cooled with a Zalman 9500.
http://img480.imageshack.us/my.php?i...rscreen8ry.jpg Link to an earlier run (was the only one i could find.
couldnt let this thread die without posting in it first. Pentium 4 3.46EE @ 3.515Ghz.mind you thats due to my mobo being factory set at 271fsb for some reason.hope to achieve 3.73Ghz+ before replacing mobo and cpu.
XE oc Thread cool. So here is mine.
This is for 24-7 use on water.
300x15 4x Primestable
CPU-Z Database (ID : 113640)
Submitted by Natas
Submitted on Sun, 20 Aug 2006 23:40:58 +0200 with CPU-Z 1.36
CPU : Intel Pentium Extreme Edition (*1)
CPU Arch : 2 Cores - 4 Threads
CPU PSN : Intel(R) Pentium(R) D CPU 3.73GHz
CPU EXT : MMX SSE SSE2 SSE3 EM64T
CPU Cache : L1 : 2 x 12/2 x 16 KB - L2 : 2 x 2048 KB
Core : Presler (65 nm) / Revision : C1
CPUID : F.6.4 / Extended : F.6
Freq : 4505.88 MHz (300.39 * 15)
MB Brand : ASUSTeK Computer INC.
MB Model : P5WDG2-WS
NB : Intel i975X rev C0
SB : Intel 82801GB (ICH7) rev 01
RAM Size : 2048 MB
RAM Freq : 500.7 MHz
RAM Type : DDR2-SDRAM Dual Channel
RAM Ratio : 3:5
RAM Timings : 5-4-4-15
Slot 1 : 1024MB (PC2-8000)
Slot 1 Manufacturer : Crucial Technology
Slot 2 : 1024MB (PC2-8000)
Slot 2 Manufacturer : Crucial Technology
