Good show :toast:
Can't wait for the cascade action :D
Good show :toast:
2x6800U under cascade :slobber:
Good luck with cascade. Unfortunately -100C isn't enough :D
We'll just have to wait and see on that:DQuote:
Originally Posted by Sampsa
By the way, Congrads on the world record, great job! :toast:
OPP
You are quite funny :DQuote:
Great work! :banana3:
Guess you had no problem making the top 20 :p:
Can't wait to see the results of the -100c Cascade Give em hell!
DGeNeRaT3
Good start with SLI OPP. :up:
So close to 25k in 03 damn...would of been a nicer number to hang your hat on...;)
That's one of the problems of SLi, you have to get 2 good cards and not 1.
Regards
Andy
Yea, I really believe that one card is holding back. The core of 470 is just plain bad.Quote:
Originally Posted by zakelwe
I won't be able to test it untill tomorrow. If it's the case, I'll replace the card and try again on my water setup before going Cascade.
OPP
3D Mark 03
Move over CPU City... OPP & Xtremesystems.org is coming through :D
3D Mark 05
Head to head!
Vapo LS / LN2 vs. Cascades.... Sampsa & Kamu (www.muropaketti.com) vs. OPP (www.xtremesystems.org)
rememeber they have backup scores 600+ core and 1400+ mem, so cascade better help out a whole lot ;)
Vapo LS / LN2 was just warming up :DQuote:
Originally Posted by Bennah
wow still very nice with just 66.93 drivers hehe wait till ya go 76.10 heheQuote:
Originally Posted by OPPAINTER
Those aren't Futuremark approved and won't propably never be. Better to run with approved drivers so the score is legit, right?Quote:
Originally Posted by eva2000
Don't make me bust out my "buggy" back-up, lol.... :p:
http://www.xtremesystems.org/forums/...chmentid=27594
Are you sure on that boss? sure it's just one slot on both but i think MSI has some more milimeters to play, I say this because one of my MCW50-T's does not fit between the cards, unless I'm doing something wrong.Quote:
That is a difficult question to answer to be honest. In one sense you want a driver set that has no IHV cheats, so 66.93 is the one, but on the other hand as everyone is using the same IHV in this case it does not matter.Quote:
But on the other hand the top scores have been done with 66.93, which currently beats later driver with tweaks so if the later drivers are now used will that mean that the new record holder ever beat the old score and so had the fastest rig ?
But on the other hand nvidia drivers are always progressing and benching multiple drivers over time is part of the fun. It also makes people with onetime LN2 put more effort in and cost to keep up with the OEM heatsink guys with the latest drivers :p: :D
On the whole though I'd say at present 66.93 is the way to go to see who is top dog.
Regards
Andy
well i never had 66.93 drivers work in SLI for either of 2x XFX 6800GT PCI-E or 2x eVGA 6800U PCI-E on Asus A8N-SLI Deluxe and DFI NF4 SLI-D only driver that worked in SLI was 71.24, 71.25, 71.84, 75.90, 76.10 and 76.41
You guys need to get some $$ and go for the dual tyan PCI-e board.
It supports two 16x pci-e slots via two "INDEPENDENT NVIDIA CHIPSETS ON ONE BOARD" and yeilds up to a 1k lead in 3dmark 2k5 due to the increases speed.
2 opterons 248 2.2ghz =$900
tyan mobo $500
2x 6800u =you already have
4x512 ch-5 ecc/reg ram $450
http://www.hkepc.com/hwdb/tyan-x16sli-3.htm
http://www.hkepc.com/hwdb/tyan-x16sli-4.htm
That's a good start OPP! Yep, it definitely takes two good cards to pull of top SLI scores. Aside from having two solid cards, I also have a secret "hint" on maximizing your overclock in SLI. PM me if you'd like:)
Having another benching sesh soon then ;)Quote:
Charlie... nevar bring out that back up score :D
OPP is slowly crawling up there... instead of the usual fashion of 'BANG... #1!'
do tell :DQuote:
Originally Posted by mdzcpa
sandybeach
You can't o/c the CPU there so I don't think you can take WR. MAYBE in 05?
yeah only talking about 05 :) since 2k1 is about to be phased out 2k5 will take over as the preimer benchmark and cpu has little effect at all on score :)
plus the folding power of a dual 2.2-2.6ghz opteron setup "yum"
I think he's refering to the use of LN2@cpu in the last runs, wich are not published yet ;)
